Author Topic: 1978 CB750K Unknown parts  (Read 341 times)
Offline dubepj
« on: August 29, 2022, 09:21:07 AM »
Got this bike in pieces.  this is leftover.  Any one know where they go??  Hope wheels don't fall off if I don't put these on.  Thanks
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 1978 CB750K Unknown parts
« Reply #1 on: August 30, 2022, 08:06:38 AM »
The tin bracket with the stud bolts through the frame behind the brake pedal below the swingarm. It uses a small acorn nut to secure it. Pretty sure it has to be installed before the swingarm is put in place and it serves to guide the drain tube from the vapor canister under the battery box around the leading edge of the swingarm. The drain tube continues to the rear and is secured to the muffler bracket.
I don't recognize the other two pieces, they might be for something else altogether.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dubepj
« Reply #2 on: August 30, 2022, 08:16:14 AM »
Thanks Madmtnmotors,
I'll see if i can find, where it goes.
« Reply #3 on: August 30, 2022, 08:26:29 AM »
TAMTF...
Wilbur
Projects:
