Author Topic: CB750K2 replacing wire harness - coil connector differences!  (Read 378 times)
« on: September 03, 2022, 08:36:43 AM »
In process of replacing the wire harness (Yamiya replacement) on my CB750K2 - all going well until I come to hooking to the Dyna S to the black/white connector which also attach the coils.
Previous wire harness had 4 connections:
Where 2 connections taken up by each black/white coil wire leaving one for Dyna S power wire.
New harness has a 3-way connector only
No room for Dyna S.
What to do? I am not an electrical genius….
Thanks
Andy
Re: CB750K2 replacing wire harness - coil connector differences!
« Reply #1 on: September 03, 2022, 09:15:05 AM »
Dont ever remember a 3 way on the black/white and i thought dyna said to connect to a black
« Reply #2 on: September 03, 2022, 09:22:35 AM »
I had it connected to the 4-way black/white on the previous harness. I could hook it up to black but I thought it had to go through the coils?
« Reply #3 on: September 03, 2022, 11:32:46 AM »
Here are some good Dyna instructions if it helps. https://manualzz.com/doc/23663962/dyna-s-ignition-installation
Offline newday777
« Reply #4 on: September 03, 2022, 11:35:55 AM »
I think it's just for power on with key.
Someone posted they made a 2 way connector to the brake power
Stu
My current rides
Prior bikes....
« Reply #5 on: September 03, 2022, 12:03:17 PM »
Ok so all lights/horn work as well as gauge lights and idiot lights so that’s all good. Press starter button and it sounds normal - good healthy attempt at start but it’s not firing up. Gas is on :).
I plugged the Dyna S into the 4-way black connector.
Any thoughts?
« Reply #6 on: September 03, 2022, 12:22:31 PM »
Ok it fires up and runs but…I went back to how I had wires before…
In headlight shell:
Black/white (handlebar switch) goes to black (handlebar)
Black/white harness goes to black connector
Maybe it’s because I have later handlebar controls?
Anyway it runs is there and risk of crossing these wires?
« Reply #7 on: September 03, 2022, 12:24:35 PM »
More
The orange wire is the Dyna S into the 4-way black
« Reply #8 on: September 03, 2022, 12:25:15 PM »
Thats not correct by hond colours
Black should be power into kill switch
Black/White is power out of kill switch to coils
« Reply #9 on: September 03, 2022, 12:36:35 PM »
Black/white is coil power with its origin from ignition key switch.  Kill switch on handle bar is included in the route, which is connected in headlight bucket.
Each coil need a wire from that. It does not matter which screw connection on Dyna coil.
Blue to the other screw connector on coil for 1:4.
I have that coil on left side.
Yellow to coil for 2:3.
Both my CB750 have an extension wire from black/white to left side cover where I have located a relay which it will turn on.
From relay thicker wire feeding coils. Power direct from battery via a hanging 10A fuse.
« Last Edit: September 03, 2022, 12:39:59 PM by PeWe »
« Reply #10 on: September 03, 2022, 02:05:44 PM »
As pewe said, extra is the ignition switch power out is the black wire that feeds everything
« Reply #11 on: September 03, 2022, 02:54:13 PM »
Thank you both very much appreciated!
