Author Topic: Sander/polisher vs. buffer/waxer on Boats  (Read 642 times)
Offline Prospect
« on: September 14, 2022, 02:02:05 PM »
I recently bought a sail boat and am prepping for the end of the season. From what I've been told it's a good idea to wax the boat before winter storage as a protective measure.
I'm thinking of getting one of these two bit I'm not sure which is better for waxing boats. I'd have to wax the hull meaning that I would have to hold it at shoulder height so the lighter the better. But, being able to hold the heavier one with both hands is a plus.
Buffer/waxer
https://www.canadiantire.ca/en/pdp/certified-palm-grip-buffer-waxer-6-in-0390834p.html?gclid=Cj0KCQjw94WZBhDtARIsAKxWG-9F7X47PTHvckehsW8Kz1ltpuwLeGU0YsyIcXYqizpAeyX3jn-Lw-kaAiWYEALw_wcB&gclsrc=aw.ds#store=459
Sander/polisher
https://www.canadiantire.ca/en/pdp/simoniz-light-duty-right-angle-polisher-sander-7-in-0399013p.html?loc=plp
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline jgger
Re: Sander/polisher vs. buffer/waxer on Boats
« Reply #1 on: September 14, 2022, 04:20:41 PM »
That angle one is probably the better of the two. The only downside is that it doesn't say if it is dual action. Unless you are experienced with a straight buffer you can easily burn nasty looking swirl marks. The dual action machines are much more forgiving. Even the Harbor Frieght d/a works pretty good. I have a Griots and love it. I think autozone carries that brand.
Another rookie mistake is thinking that lambs wool is a nice soft pad, it isn't. They are suprizingly aggressive, mix that with a non dual action polisher and you can do some real damage.
Maguire,'s has a forum you can learn alot from, plus some pretty decent products. But beware you may be headed down a very deep rabbit hole!  Just remember the smaller the machine both in size and amperage, the longer the job is going to take.
Good luck and remember" pics, or it didn't happen "!
« Last Edit: September 14, 2022, 04:22:19 PM by jgger »
Offline Prospect
« Reply #2 on: September 14, 2022, 07:12:42 PM »
Thanks so much for the reply. I'll probably go with the angle one then. The boat came with quite a bit of polishing compound and it's amazing the results that you can get.
I have polished cb750 forks, engine covers etc. Not something I enjoy.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
