Author Topic: brembo calipers  (Read 1112 times)
Offline mad mike
brembo calipers
« on: September 17, 2022, 10:09:14 AM »
Hi, Is anyone running the SMALLER Brembo calipers  on a CB750  [as fitted to the R65 bikes] as front brakes for a race bike ? .... please advise if so,  ..... Do they overheat ? ....what type of pads? .... how many races do the pads last ?  I have the option of using the small Brembos  R65 type,  or the larger  [K100RS type]  I really like the look of the smaller ones If they are up to the job?  Thanks in advance for any advise.    Mike.
« Last Edit: September 17, 2022, 10:15:58 AM by mad mike »
BELIEVE NONE OF WHAT YOU HEAR, AND ONLY HALF OF WHAT YOU SEE.
Re: brembo calipers
« Reply #1 on: September 18, 2022, 03:48:30 PM »
I use the F05's with 300mm cast iron rotors on my 550. Because the the softer iron rotors I use Ferodo Platinum pads which are not race pads, but easier on the rotors. I believe braking is as good as it can get with these small calipers.
Sorry to say though with a heavier 750 you might want to use larger calipers.
Offline mad mike
Re: brembo calipers
« Reply #2 on: September 19, 2022, 01:01:28 AM »
Thank you for the advice , I will use the larger calipers,  can't have too much stopping power.
Offline bear
  • Leeton in Australia
Re: brembo calipers
« Reply #3 on: September 20, 2022, 01:04:41 AM »
I have used the larger 08's they where the best that where available to me,
ie;pre.1970 historic road race sidecar.
Offline voxonda
Re: brembo calipers
« Reply #4 on: September 23, 2022, 10:50:42 AM »
The p05's are used on road 750's, but for racing the P08's are prefered. You can lighten them a bit by shaving off some of the back and by using the lighter hard anodised aluminium pistons. Also changing the bolts for Titanium ones helps.
Offline mad mike
Re: brembo calipers
« Reply #5 on: October 12, 2022, 01:24:25 AM »
   Thank you for all your advice gents, greatly appreciated. [as always]  Mike.
Offline corky
Re: brembo calipers
« Reply #6 on: October 12, 2022, 09:33:16 AM »
Just to verify, do the P08's fit to spoked wheels without any modifications?
Thanks,
Daniel
Re: brembo calipers
« Reply #7 on: October 12, 2022, 09:52:24 AM »
In my opinion, the only reason to run the old Brembos is when they are required by vintage racing rules. ;) Also, they aren't easily mounted on CB "K" model forks.
