Author Topic: what's a great fuel additive for ethanol gasoline;to keep the ethanol mixed ?  (Read 909 times)
Offline grcamna2
Here in Ca. the gasoline pumps say "up to 10% ethanol"... there's more ethanol 'in the mix' than just 10%..  ::)
What's a very good additive to add to my tank that'll keep the ethanol/water stuff completely and equally mixed within my fuel tank ?
 I notice the ethanol/water drops to the bottom of the fuel tank where it gravity feeds in through the petcock down to the carbs into my engine;lot's of pinging going on,especially on reserve !
This happens after about a week with a tank of top tier Shell gas.
« Last Edit: September 17, 2022, 07:19:48 PM by grcamna2 »
75' CB400F/'bunch o' parts'
I've used both Marvel Mystery Oil and synthetic 2-stroker oil in the tank for this issue. Mine sat all last winter with a full tank of gas and about 2 ounces of 2-stroke (chain saw, says the label) oil, and no separation at all. Fired right up, came May!
Offline grcamna2
You used MMO in E10 which kept it from having 'phase separation' ?
Fuel stabilizer as discussed in another thread will help?
This one is that kind of stuff, right?
A member that had to design his own ignition system to run his CB500 on local fuel in Brazil wrote about 30%  ethanol.
Offline grcamna2
Oh yes,StarTron..  does it accomplish what it advertises ?
Did you try StarTron yourself Per ?
No real test yet
I bought it at my nearby shop with dyno. Not expensive so bought it just for sure.
My bikes get Shell V-Power marked max 5% ethanol, maybe less.
I added a dose (2cl) into the K6 tank a week ago after I thought fuel had got condense water. Probably false alarm.
The guy I bought it from praise its function. He adds it in all his vehicles when parked for a while. Lawnmover, snowmobile, bikes and even cars when they use the lower octane 10% sh!t fuel we also have here.
I usually start my bikes midwinter, let them idle for a few minutes.
My garage is warm and dry, no worries about rusting pipes. My K6 has stainless.
Offline grcamna2
No real test yet
Ok,I understand,thanks.  :)
If tank already has a layer of ethanol and water, it is better to drain tank, refill with fresh fuel.
Separate ethanol + water from gasoline has been up before. Maybe possible to do with old fuel.
Offline grcamna2
Ah,ok Per,  ;)
I have never done that yet and I imagine this tank needs to be dried-out and cleaned;the left-overs of ethanol fuel  :( repulsive to the operation of my engine.
