Author Topic: coil leads  (Read 404 times)
Offline mart
coil leads
« on: September 18, 2022, 08:11:26 AM »
can the coil ht leads on the 350 four  be changed.
Online bryanj
Re: coil leads
« Reply #1 on: September 18, 2022, 08:35:14 AM »
Only by cutting them out of the coil and soldering then resealing, if you go to the UK forum and look in Ash's dropdox or alladins cave there is a write up on how to
Offline robvangulik
  • Honda Fourever
Re: coil leads
« Reply #2 on: September 18, 2022, 08:57:45 AM »
The same on the home page of the Dutch fourum www.cbfourclub.nl, under "Techniek", "how to", the item on top.
Ofcourse in Dutch, but with excellent pictures. ;)
Offline Deltarider
Re: coil leads
« Reply #3 on: September 18, 2022, 01:30:32 PM »
Why do you want to change them? Many HT leads may feel a bit flimsy, but usually they're still good.
CB500K2-ED Excel black
Offline robvangulik
  • Honda Fourever
Re: coil leads
« Reply #4 on: September 18, 2022, 02:41:31 PM »
Usually, not all the time. Cracked isolation etcetera.
Recall your own advice "test them in the dark"?
Offline Deltarider
Re: coil leads
« Reply #5 on: September 18, 2022, 11:22:47 PM »
[...] Recall your own advice "test them in the dark"?
Oh, absolutely, any owner of a CB500/550 is advised to do this simple test from time to time. I've seen quite a few that had either the HT leads or the plugcaps arch to the engine block. Realise this can happen intermittently. In riders reports published in Holland back then, it was reported the #1 issue people had with these bikes. I myself am still on the look out for the thin black sheaths (?) that Honda had slided over the HT leads. Actually these sheaths on mine were old and damaged, the leads themselves came out like new after removal of the sheaths. I'd like to have them again but they are hard to find, so I may have to follow the suggestion a Ducati/Guzzi mechanic did: just mount them without. Most Guzzis didn't have them anyway. Silicone spray and WD-40 can help fight issues.
