Author Topic: New Member  (Read 606 times)
Offline Rmak98
New Member
« on: September 20, 2022, 03:45:40 PM »
Hello: From Norman, Okla. Have been looking and getting info to help get the 76 550F I found about 2 months ago running.  was driven 11 years and parked for the last 35 in a garage. Lots of issues. 'You guys have been a great help. Had a '64  50 sport cub, then Yamaha 80, CL450 Scrambler, thru the 60's and early 70's, then Family and life got in the way, so just been scooters around the neighborhood, 1957  Cushman Eagle,  1970 mini trail. 81 Express SR, 85 50cc Aero.
Online newday777
Re: New Member
« Reply #1 on: September 20, 2022, 03:50:26 PM »
Welcome aboard
Stu
My current rides
Prior bikes....
Offline Kevin D
  • SE Michigan
Re: New Member
« Reply #2 on: September 20, 2022, 04:44:29 PM »
Hello Rmak. There was a time that a CL450 was the fanciest bike in Hondas lineup. Was is Candy Apple red or blue, or something else. Do you still have it? Or any of the others you mentioned?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Rmak98
Re: New Member
« Reply #3 on: September 20, 2022, 05:56:48 PM »
    Mine was Blue. Should of kept that one, the only ones I have  are the wife's 1970 50cc mini trail, the 1981 and 1985 scooters, my folks bought them to throw on their motor home when they traveled. Been working on the 76 550F i was given a couple months ago. it only had 9500 miles, and a gas   tank with so many holes in it you could see thru it. parts missing, carb 3 and 4 froze up, lights, elect  issues etc, etc. but it's running now, so I'm really having a blast.
Thanks for all the info and expertise you guys provide on the forum
Rod.
Offline tool14
Re: New Member
« Reply #4 on: September 21, 2022, 04:16:00 AM »
welcome aboard
Re: New Member
« Reply #5 on: September 21, 2022, 07:46:24 AM »
Welcome from Texas....
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: New Member
« Reply #6 on: September 21, 2022, 03:23:13 PM »
Hello from MN,
CB550 can sit under a tarp outdoors for twenty years and be revived.  Keep plugging away doing the normal, clean carbs, points, oil, and gas tank.
A revived 550 can do a 1000 miles in less than 24 hours more than once.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline Rmak98
Re: New Member
« Reply #7 on: September 21, 2022, 04:19:13 PM »
Thanks MD  and all the warm welcomes from you all. i'm impressed with how well it cleans up and started fairly easy after setting since 87. Have 135 to 145 compression, not the best, but enough to start and run.
Re: New Member
« Reply #8 on: September 22, 2022, 06:51:19 AM »
When it comes to compression numbers on these bikes, the 4 numbers being within 10% of each other is more important than the number itself.  Compression has been known to rise with running time.
