SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Front Turn Signal Stems CB750 K1
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front Turn Signal Stems CB750 K1 (Read 360 times)
Rookster
Hot Shot
on:
October 02, 2022, 06:23:39 PM »
What length are the original front turn signal stems on the K1? The ones on my K1 are aftermarket and I think they are too long. I picked up a set of early turn signals and they had these stems on them. They are about 60mm which is about 10mm shorter than the stems on my K1. Can anyone measure an original stem and provide the correct length?
Thanks
Scott
Logged
Kevnz
Hot Shot
Re: Front Turn Signal Stems CB750 K1
Reply #1 on:
October 03, 2022, 02:41:36 AM »
According to the respective parts manuals, the same part is used by 750 K1, K2 and CB500. I just measured my 500 ones and they measure the same as your one.
Logged
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Kevin D
Old Timer
SE Michigan
Reply #2 on:
October 03, 2022, 10:27:38 AM »
Here’s a photo from an original K1 part (11/70 build) but the photo has an optical delusion…..
Your part looks correct, as my NZ namesake has noted.
About 2” from bottom of hex to center of pinch bolt.
My original part is a little bit rusty.
Logged
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Rookster
Hot Shot
Reply #3 on:
October 03, 2022, 11:15:30 AM »
Thanks guys. Looks like I will be switching out the stems for these correct ones.
Scott
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
