Author Topic: cotter pins for carburators' links  (Read 672 times)
Offline _mark
« on: October 09, 2022, 09:15:09 PM »
Hi. what are dimension (diameter) and length for the cotter pins of the carburators links? I have to order them..  thanks and regards
Offline newday777
Re: cotter pins for carburators' links
« Reply #2 on: October 10, 2022, 01:38:39 AM »
As you didn't include the model bike this is on in your question, I searched through some of your posts to try to Sherlock Holmes what bike you are working on..... CB750K1?? As a former parts manager, please include your model when asking for parts help(and even asking for mechanical help) so you get the correct parts help and we don't have to ASSUME what bike you are asking for help with. Many members have more than one motorcycle....
As to carburator link cotter pins. Honda only lists the diameter, 1.0mm. They don't include the length. But, in the part number, at the end, one fiche shows 080 and another fiche shows 010. That would be 8mm and 10mm lengths.  If you get 10mm length you will have enough length to fold it over. Or if you have a local hardware shop get both 8mm and 10mm length.
I hope that helps.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #3 on: October 10, 2022, 01:41:56 AM »
Do you have the CMS parts link?
https://www.cmsnl.com/honda-cb-four_model7148/
Stu
My current rides
Prior bikes....
Offline _mark
« Reply #4 on: October 10, 2022, 08:03:34 PM »
Thanks a lot guys.
« Reply #5 on: October 11, 2022, 01:26:44 AM »
I always get them from a hardware store - different sizes and use what fits. I also used just a piece of wire and it works fine.  There are no big forces in the carb linkage.
« Reply #6 on: October 11, 2022, 08:11:39 AM »
 I have also used the little hairpin type clips from the assortment in the HELP (misc. universal parts) display at my local parts store.
Offline WideAWAKE
« Reply #7 on: October 11, 2022, 08:12:34 PM »
I couldn’t find any cotter pins small enough to fit.
I ended up using these.
Offline newday777
« Reply #8 on: October 11, 2022, 11:58:44 PM »
Thanks a lot guys.
What bike are you asking this on??
Stu
My current rides
Prior bikes....
Offline Doobie
« Reply #9 on: October 17, 2022, 02:21:21 PM »
You want an M1 x 8mm split pin. and they can be found on eBay. A bag of a few hundred costs $5-$6 at most.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
