Author Topic: Playing with electricity - wise or not so much?  (Read 1755 times)
Offline gregimotis
  • poet laureate; SOHC4.
« on: March 08, 2007, 01:13:13 PM »
1)  I have a metal rack that gives everybody who touches it a zap of static electricity.
2) I have a three-prong electrical outlet.
     a) My understanding is that the third prong on such an outlet is a groud
3) I have a six foot extension cord damages one end to make it unusable
Couldn't I plug only the third prong into the wall socket and attach the wire at the other end to my metal rack?  For some reason, I want very badly to do this.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Playing with electricity - wise or not so much?
« Reply #1 on: March 08, 2007, 02:17:07 PM »
Is the rack insulated from the ground in any way (rubber feet or whatnot)? If it isn't then I don't think your idea will make any difference.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline SD750F
    • My Business Site
« Reply #2 on: March 08, 2007, 03:03:48 PM »
Okay way too many questions here...
Are you sure that you are feeling a static potential??? Maybe you have a bad spark plug wire and getting a little kick from the coils???
And wouldn't you need a very long grounding cable when you ride???
Had to ask...
Scott
kettlesd
« Reply #3 on: March 08, 2007, 03:30:49 PM »
Had to ask...
Scott
I hope this is not the problem and he is trying to cure it by plugging into the house ground - he'd need an awful long cord!!!!! I am thinking he means a utility rack for tools and stuff?
Offline Roach Carver
« Reply #4 on: March 08, 2007, 07:26:20 PM »
or this kind of rack?
Offline Pinhead
  • 1979 CB652-ST
« Reply #5 on: March 08, 2007, 07:40:11 PM »
Yes, you could connect the "third prong" to the rack to help dissipate static electricity. That third prong is the "neutral" that goes to earth somewhere outside the house (and on each and every power line). It'd be the same thing if you had metal conduit around your wiring. The third wire (usually green) is attached to the conduit and also earthed. That should eliminate your static shock.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline scunny
  • don't call me expert
« Reply #6 on: March 08, 2007, 08:16:46 PM »
it's the volts that jolt and the mills(amps) that kill
I would ask why people are getting a shock from your rack, have you something electrical on it, or have you a nylon based carpet and it's the people who hold the charge and get a shock when they touch your rack. jeez I just about did a TT impersonation  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Steve F
« Reply #7 on: March 08, 2007, 08:20:04 PM »
I think the rack is already acting as the ground, and you're discharging the static potential that your body is storing TO the rack.  Adding a ground may just make it an even better ground for the static to go.  I wouldn't advise wiring a cord to the rack to plug into an outlet....too easy for things to go wrong, like energizing the whole rack with AC.   :o  :o  :o  Avoid static build up by adding moisture to the air with a humidifier.
Offline scunny
« Reply #8 on: March 08, 2007, 08:32:25 PM »
it's a well documented fact that beer fumes are moisture laden.
SteveF is right, don't f#$k with electricity
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #9 on: March 09, 2007, 12:36:19 AM »
Details are sparse.  So, on the assumption this is talk of a rack in an house, I'd also guess that there is a carpet floor involved, too.
So it would work like this.  Person shuffles along carpet and picks up a static charge (bunch of homeless ions milling about with no place to go).  When said person touches the rack with a ratio of ions more or less than the person carrying the homeless, the person either collects or sheds ions,  Zap!   If the rack is already grounded, the charge drains away to earth which has lots of area for homeless ions to dance into the wee hours of the millennia.  If the rack is insulated, it stores ions delivered by the shuffling person and the next person to come along who doesn't have the same ratio of ions either collects or sheds ions, zap.
Earth grounding the rack may help sometimes to lessen the zap.  Or, it might increase the zap intensity.  But, make certain that your damaged extension cord ONLY makes a connection to that third, earth ground wall outlet socket hole.  You don't want 115v AC running around loose in the house, unless you want a MUCH more intense ZAP taking place.
Also, electrons can jump into the atmosphere and does so at an increased rate when more conductive particles are present in the air, such as water molecules (Humidity).
Probably the best way to reduce your zapping problem is to humidify the air in your house.
Or, replace your carpet with one that has embedded carbon fibers.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #10 on: March 09, 2007, 03:46:30 AM »
Boy, that brings back memories. :)  I use to load those plastic chairs in school with static, I could get the static change to bridge a half inch gap.  Could usually hear the person who got hit yell from the next class. ;D ;D
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Tim2005
« Reply #11 on: March 09, 2007, 06:14:40 AM »
I'd definitely not do this, as if something else on that circuit develops a fault then the rack could become live. Ground cables have insulation on them for good reason!
Offline gregimotis
« Reply #12 on: March 09, 2007, 07:38:37 AM »
Well, people would quit touching my rack, then.   ;)
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #13 on: March 09, 2007, 09:27:55 AM »
Would rubbing charcoal or ash into your carpet produce the same result?
CB750K4
« Reply #14 on: March 09, 2007, 10:50:34 AM »
I theory, yes to charcoal, as it is by definition, carbon and mostly conductive.  Probably darken your carpet and clog up your vacuum, too.
Ash is is not well defined as to material content.  It may be insulative or conductive.  Ash is a remnant of combustion, and that part of the fuel that didn't burn.  If there were metals in the fuel, for example, the ash could be conductive and give those homeless electrons a multitude of highways to travel and keep them from congregating in one place looking for a place to jump.
eldar
« Reply #15 on: March 11, 2007, 08:22:48 PM »
So where is this rack? I think that is the vital question that needs to be answered.
Offline mrbreeze
  • Not your average
« Reply #16 on: March 11, 2007, 08:44:08 PM »
I would.....A. leave it the way it is......a little gag to play on your friends (if it just a harmless static shock) or B. try putting a rubber mat down under the legs of this rack. Hope you solve your dilema!!!
MEMBER # 257
eldar
« Reply #17 on: March 12, 2007, 09:23:33 AM »
Could do wood too, to insulate the rack.
