Author Topic: 1975 cb550k1 shifter shaft seal replacement help  (Read 1760 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
Re: 1975 cb550k1 shifter shaft seal replacement help
« Reply #25 on: October 23, 2022, 09:26:16 AM »
So semi good news.
The leak isn’t coming from the shift shaft seal I replaced.
It’s very hard to see where it is coming from.
I think the pump area.
I’ll post some pictures so you guys can see.
Maybe you guys can let me know what I need to do to fix the leaks.
Thanks.
JD
1975 CB550K1
Offline grcamna2
« Reply #26 on: October 23, 2022, 09:34:16 AM »
So semi good news.
Thanks.
Check-out posts#15 & 17 here of member 'bryanj'.
The oil pump seals.
75' CB400F/'bunch o' parts'
Offline JDrider
« Reply #27 on: October 23, 2022, 12:58:29 PM »
I ordered the o rings and a new oil sender
« Last Edit: October 23, 2022, 01:08:17 PM by JDrider »
JD
1975 CB550K1
« Reply #28 on: October 23, 2022, 03:12:56 PM »
Where did you order from as the cover O ring is not listed anywhere
« Reply #30 on: October 23, 2022, 03:29:55 PM »
Bit of advice, you need to use an impact driver to undo the 3 countersunk cover screws BEFORR taking the pump off the bike(also impact driver)
If bike is vertical oil will not leak out
Offline JDrider
« Reply #31 on: October 23, 2022, 03:32:11 PM »
I don’t think the cover is leaking so I don’t plan to open that.
Thanks for your help. I appreciate it.
JD
1975 CB550K1
« Reply #32 on: October 23, 2022, 03:36:23 PM »
Its more often the cover than the pump to block ones
Online dave500
« Reply #33 on: October 24, 2022, 01:04:06 AM »
ive had the pump to block ones leak but never the cap.
« Reply #34 on: October 24, 2022, 01:46:32 AM »
Mostly the other way round here Dave, especially if the motor has been sat for a long time
Offline JDrider
« Reply #35 on: October 24, 2022, 02:44:31 AM »
Bryan do those o rings look good to use?
Thanks
JD
1975 CB550K1
« Reply #36 on: October 24, 2022, 07:55:58 AM »
Cant tell from a photo but if sold retail as a kit i would hope so with the litidgeous nature of the USA
