Author Topic: Shifter drum question. Where does the big wheel ride?  (Read 1223 times)
Offline rhinoracer
« on: March 09, 2007, 02:53:58 AM »
Can somebody tell me for certain if the large wheel of the shifter rides in the outer or the inner groove in the shifter drum. Took some pictures and looking at the Clymer illustrations it looks as if it rides on the outer one, but when assembling it falls naturally into the inner groove.
Baja native.
Offline rhinoracer
Re: Shifter drum question. Where does the big wheel ride?
« Reply #1 on: March 09, 2007, 02:59:44 AM »
Here's alarger pic.
Baja native.
Offline Clutch Cargo
« Reply #2 on: March 09, 2007, 04:21:20 AM »
Good luck putting all of those springs and levers back together - that's a tricky little bastard.
The inner spring is the worst.
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline Jonesy
  • Shop Rat
« Reply #3 on: March 09, 2007, 04:25:16 AM »
According to this website:
http://www.salocal.com/sohc/tech/tranny/slipgear.htm
It looks like you assembled it properly. The shifter arm rides in the outer groove.
Offline rhinoracer
« Reply #4 on: March 09, 2007, 07:06:54 AM »
Thanks, You're right there's the shifter arm in the outer groove of your pic.
It did take almost an hour and a few banged fingers to put back together.
Baja native.
« Reply #5 on: March 09, 2007, 07:59:09 AM »
I did this last year and its not nearly as bad as I thought it would be. Just need to remember where everything goes. Good luck!
Andy
