Author Topic: And the build begins!!!!!  (Read 2094 times)
Offline JP
« on: March 09, 2007, 07:42:33 AM »
Well, it began a while back when I tore down the bike and had the fram powder coated- so I've got a nice little head start ;D
This build is for my personal 750SS that I plan on keeping.  I will post pic's soon but for now you will be forced to live with only my resent parts list from cyclexchange.net
1.  big bore
2.  gaskets of course
3.  clutch plates
4.  full Dyna electronic ignition and 3 ohm coils
and let's not forget........
5.  31mm Kehien CR carbs!
Now salivate, I know I am!
JP
Rockers Unite!  I want to start a Ton Up/Rockers bike club around the Atlanta area, who's with me?  Send me a message.
Re: And the build begins!!!!!
« Reply #1 on: March 09, 2007, 07:57:34 AM »
Sounds good JP and looking forward to those pics  ;)
good luck,
Andy
Offline Rhonda750F
  • In the Works!
    • Gallery:
« Reply #2 on: March 09, 2007, 11:54:51 AM »
What year Super Sport?
Sounds like I'll be following this thread.
Paul Z.
1978 CB750 F rolling chassis for sale. PM me.
Offline JP
« Reply #3 on: March 09, 2007, 12:54:19 PM »
1978
I forgot to mention that I have recieved my rear shock from a cbr954 that will be adapted to this bike.
This one will also have SEVERAL modern day frame sliders for the next time I lay one down  ;D
JP
Serenity
« Reply #4 on: March 09, 2007, 10:02:20 PM »
 :D WTG sounds like youll have fun playing
Offline JP
« Reply #5 on: March 15, 2007, 06:32:00 PM »
Oh happy day!!!  Cyclexchange.net Rocks!!
I thought I'd add in a pic of the beginning
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #6 on: March 15, 2007, 07:43:42 PM »
            MERRY CHRISTMAS!!!!!!!!! ;D      No? ???      I know.   HAPPY BIRTHDAY!!!!!!! ;D     No? ???
           Well, at any rate, I'd sure like to be opening those packages!!  :o 8) ;)
           Have fun there JP! ;)
                                                              Later on, Bill :) ;)
Member # 1969
Offline Rhonda750F
  • In the Works!
    • Gallery:
« Reply #7 on: March 16, 2007, 07:20:20 AM »
Nice shipment there!  Is the frame powdercoated or is it paint, looks good.
Check your email I have some questions for ya. :)
Paul Z.
Offline Lumbee
    • My pics...
« Reply #8 on: March 16, 2007, 07:26:16 AM »
"I'm not a welder, but I play one on HondaChopper.com"
Offline Goldbug
« Reply #9 on: March 16, 2007, 08:36:01 AM »
I really like the frame color.
Eventually I'd like to take mine down like that, powder coat it and wire the entire bike from scratch. I'd do it now but I don't have a garage. I guess that's what a single guy's livingroom is for though. Next winter?
Offline JP
« Reply #10 on: March 21, 2007, 06:28:47 PM »
Just got the cylinder block back from the machine shop.  Now the pistons from cyclexchange slide right into place....beutiful!  Hopefully tommorrow I will clean up the bottom end and start the assembly process if I don't get too busy.  I have been working on a "74 750  and a '75 550 tank, I added a pic of them- send me a pm if you are interrested (they still need a good wet sanding and another coat of clear, though- the orange peel in the clear coat is due to being drunk and not using enough clear because I was afraid that it would run ;)).
JP
PS- For those sharp tack's out there, yes it is an F2 engine- The entire thing, block and all, has been beed blasted.
« Last Edit: March 21, 2007, 06:35:21 PM by JP »
Offline JP
« Reply #11 on: March 22, 2007, 08:00:39 PM »
ARRRRHHRRR!!!!! I just snapped a ring!!!!  I feel like such a numb nutt.  I didn't even do it while ringing the piston.  I did it when I was turning the crank to get the #2 rod at tdc to get the piston on.  As I turned the crank, the #3 piston got hung on the lower end and snapped the middle ring. But now that I type this, it seems unlikely that it happened like that and that I probably snapped it while putting it on the piston. Well either way, I guess it's good at least that I found it before I put it all together.
JP
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #12 on: March 22, 2007, 09:43:29 PM »
I have snapped rings on my 350F at least twice.  The next time I rework the top end, I will have the shop put the rings on for me.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Lumbee
    • My pics...
« Reply #13 on: March 23, 2007, 05:57:39 AM »
...I just went through that last week.  I got a pistion jammed in the case while turning the crank to repostion the pistons.  Piston was jammed, and I couldn't turn the crank backwards, so out comes the dremel to curt the piston out.   >:(  Board member sent me a piston, so the jugs and head on one now.  :)  I'll get the rest of it back together this weekend...is it 5 o'clock yet?   ;D
