Author Topic: My K8 re-conditioning  (Read 15592 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: My K8 re-conditioning
« Reply #250 on: March 15, 2023, 08:55:51 am »
I have used a pick between the plastic and the bung. Once you have an opening between the filter and the bung large enough to get needle nose pliers on the filter I just grab the filter, twist, and pull.
EZPZ
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline denward17
« Reply #251 on: March 15, 2023, 09:27:05 am »
Good tips Guys, will try later today.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #252 on: March 15, 2023, 09:36:47 am »
Good to see it running 👍
Offline denward17
« Reply #253 on: March 15, 2023, 10:19:05 am »
Used a tap to screw into the old filter sock and was able to get it started out, then it broke off inside the tank.
Little while later and shaking the tank upside down, it fell out.
Will be rinsing the inside with some alcohol or something later before installing the new petcock.
Offline denward17
« Reply #254 on: March 16, 2023, 12:54:51 pm »
Spent the day cleaning up the inside of tank using Evaporust (soaked last night), then some Dawn dishwashing liquid, followed by a good rinse.
Added some alcohol to help remove any residue, then used air compressor and let it sit in the sun for about an hour to dry out.
Installed new petcock, added some fuel to make sure it didn't leak, then installed on the bike, along with side covers and seat.
Still need to set the timing with a timing light before going on the first ride.
After a few miles will try to sync the carbs (they were bench synced but need to be set with vacuum.
Offline Mark1976
« Reply #255 on: March 16, 2023, 01:59:29 pm »
Gotta love it when a plan comes together. Get looking ride, well done.
Start with the end in mind...
Offline grcamna2
« Reply #256 on: March 16, 2023, 05:39:15 pm »
The bike looks good sitting there after it's nice top-end rebuild and just waiting to get on the road  8)
Offline denward17
« Reply #257 on: March 17, 2023, 02:50:28 pm »
I took it for a short hop this afternoon, as rain was moving in.  I only went about 4 miles.
It ran ok as long as I stayed above 2500-3000 RPM.  Might have some fine tuning to do next week.
Is it best to put a a few miles on it before syncing the carbs, or should I go ahead and do that?
« Reply #258 on: March 17, 2023, 03:14:21 pm »
Go ahead and sync the carbs. There should be no reason to delay it. You don't expect cables to stretch and affect carb tuning, nor anything else I can think of off the top of my head.
Never hurts to strobe check the timing again after sync.
Offline grcamna2
« Reply #259 on: March 17, 2023, 04:49:20 pm »
I find the carb. synch does change after the engine fully breaks-in on all 4 cylinders.
Offline BenelliSEI
  • 1969 cb750
« Reply #260 on: March 17, 2023, 08:03:33 pm »
Do it ASAP, and then after a few hours of run time. You’ll be rewarded.
« Reply #261 on: March 17, 2023, 11:06:29 pm »
Make sure that valve lash and ignition are correct before carb sync.
Offline grcamna2
« Reply #262 on: March 18, 2023, 12:03:42 am »
Cold valve lash checks and check that the cam chain is adjusted.
Offline denward17
« Reply #263 on: March 20, 2023, 12:26:53 pm »
Was having a few idles issues.
Changed the condensers, didn't seem to help with a backfire condition.  So today I changed out the points to some I purchased form vintagecb750, I didn't hear anymore backfire after that change.  They were made in Taiwan, hopefully they are ok for now.  Want to get the bike running better on old ignition system before I change over to electronic.  I purchased a Dyna knockoff, if it doesn't work will try Hondaman's system.
I also synced the carbs, they were pretty close from the bench sync, but using #2 as reference, I did adjust 1, 3 and 4 just a little.
See pic attached, good enough for now.
Adjusted Fast Idle (choke).  It was idling good at about 12-1300 RPM, so left it be for now.
Argh.....  as I was taking off the right side cover, both top tabs broke off.  Not surprising since these were original.  The PO had already attempted some type of glue fix.  I will try some JB Weld plastic epoxy before buying another set.
Will go for another short ride when weather warms up later this week and see how it runs.
« Reply #264 on: March 20, 2023, 12:54:30 pm »
Yes, I'd go for a few testing rides and see how she does.
What car is that in the pic above? Looks Japanese?
Offline denward17
« Reply #265 on: March 20, 2023, 01:03:43 pm »
It is, '21 Mazda MX-5 (Miata).
Offline denward17
« Reply #266 on: March 27, 2023, 10:48:56 am »
Installed an electronic ignition today (ebay Chinese brand), it seems to run fine at idle in the garage.
Need to take it for a spin to see how it runs on the road, waiting for rain to clear out.
Offline BenelliSEI
  • 1969 cb750
« Reply #267 on: March 27, 2023, 03:41:36 pm »
Share a photo, curious which one you bought?
Offline denward17
« Reply #268 on: March 27, 2023, 05:18:32 pm »
Looks like the one in this post #282, not my pic.
http://forums.sohc4.net/index.php/topic,158702.msg2238802.html#msg2238802
« Reply #269 on: March 27, 2023, 09:30:08 pm »
I ordered 2 of those Dyna-S knock-offs. From USA.
Only the label that is missing and blue box
5 ohm coils (Dyna look) from China.
Offline denward17
« Reply #270 on: March 28, 2023, 09:39:48 am »
Visited my son for a quick stop trying to get my riding legs back, so to speak.
Put about 28 miles on it this morning to check the electronic ignition, seems to run good.
No WOT as of yet, only about 48 miles since top end rebuild.
« Reply #271 on: March 28, 2023, 10:26:23 am »
Congratulations!
It is a very nice feeling to ride after an engine restore.
More happiness when it does not weap oil either ;)
Offline denward17
« Reply #272 on: March 28, 2023, 10:46:25 am »
Congratulations!
Absolutely a good feeling, and no leaks as of yet (fingers crossed).
Offline BenelliSEI
  • 1969 cb750
« Reply #273 on: March 28, 2023, 02:07:32 pm »
Bike looks great! Well done.
« Reply #274 on: March 30, 2023, 06:34:49 pm »
My, but that's a good-looking bike!
