Author Topic: My K8 re-conditioning  (Read 18919 times)
Offline Mark1976
Re: My K8 re-conditioning
« Reply #350 on: May 25, 2023, 01:51:19 PM »
Damn attractive bike ya got there...
Start with the end in mind...
Offline newday777
« Reply #351 on: May 25, 2023, 01:55:50 PM »
Sweet
Stu
My current rides
Prior bikes....
Online Stev-o
« Reply #352 on: May 25, 2023, 03:56:42 PM »
Looks fantastic and paint color appears to match perfectly
Offline denward17
« Reply #353 on: June 01, 2023, 11:15:20 AM »
Broke out the simichrome and touched up a bit.....
Offline grcamna2
« Reply #354 on: June 01, 2023, 11:18:00 AM »
 8) 8)
Offline BenelliSEI
  • 1969 cb750
« Reply #355 on: June 01, 2023, 12:56:14 PM »
 8) 8)
+1. Very nicer!
« Reply #356 on: June 01, 2023, 01:08:39 PM »
Looks very nice.
David
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #357 on: June 01, 2023, 01:25:25 PM »
Great work
Offline denward17
« Reply #358 on: June 02, 2023, 03:59:24 PM »
Discovered a leaking oil tank line this afternoon after a 20 mile ride.  Will be calling a few hydraulic shops next week to see if they can be repaired.
« Reply #359 on: June 02, 2023, 06:52:06 PM »
You likely will need to harvest the ends from your old lines and the shop is likely to have tools to do this. If they don't then several good measurements and then you will dissect your hoses for the ends. They will need to clock the ends correctly. So, they get the new hose made correctly. But they would be unlikely to have ends that mate to the motor and tank correctly as they are custom parts Honda spec'd.
Offline BenelliSEI
  • 1969 cb750
« Reply #360 on: June 05, 2023, 05:58:51 PM »
Can’t tell from the photo, where is it leaking?
« Reply #361 on: June 05, 2023, 09:56:37 PM »
Is the alu cruch washer OK and properly tightened at the tank connection?
If it can leak and flow downwards.
Offline denward17
« Reply #362 on: June 06, 2023, 04:39:00 AM »
I don't think it is leaking at the fitting on tank, it appears the hose itself is weeping.
Will know more when I have a chance to remove it, traveling this week, will get to it next week.
Offline BenelliSEI
  • 1969 cb750
« Reply #363 on: June 06, 2023, 09:38:15 AM »
Neither hose runs at any real pressure, so that would be odd. Sure the kicker seal isn’t leaking and dripping on the hose?
Offline denward17
« Reply #364 on: June 06, 2023, 01:13:28 PM »
Thanks for the tip, will check that.....
« Reply #365 on: June 06, 2023, 05:06:24 PM »
How is the bike running....any extra power etc?
Offline denward17
« Reply #366 on: June 07, 2023, 07:13:34 AM »
^Well, I haven't been WOT yet.  Only have about 350 miles.
And, I really don't have a reference, but the engine responds well the couple of times I went to about 6-7K RPMs in 2nd and 3rd.
The bike was barely running when I got it, and too dangerous to try to ride, so that's the reference I was referring to.
« Last Edit: June 07, 2023, 07:40:51 AM by denward17 »
« Reply #367 on: June 07, 2023, 12:14:27 PM »
At 350 miles you can open it up......it'll be fine. ;)
Offline denward17
« Reply #368 on: June 14, 2023, 12:30:17 PM »
Installed new oil lines today, what a pain.
I was a little concerned, had a small kink in the feed line (back hose from oil tank). I let it run in the garage for about 15-20 mins.
No oil leaks and good oil pressure according to gauge on the oil galley.  Tank was getting hot and I could see a little bubbling inside the tank, so I guess the oil line is ok.
Offline scubanerdnick
« Reply #369 on: July 03, 2023, 05:41:06 AM »
I just bought a 1978 myself and really enjoyed reading through this entire thread!  I learned a ton from reading all the comments and your bike looks beautiful.  I learned to ride on a 1978 CB750K in that exact color and pinstriping.  I bought this one to try to recreate it and to see one like I remember in your thread was pretty inspiring!  Beautiful bike and great documentation for everyone to see the evolution.  Thanks for sharing it.
Offline newday777
« Reply #370 on: July 03, 2023, 06:00:08 AM »
Welcome aboard Nick
Are you going to start your own project thread on your bike?
Also, go to the new members introduction section and introduce yourself and your bike. Pictures are always welcome.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #371 on: July 03, 2023, 07:54:40 AM »
Welcome aboard Nick and Thanks, good Luck with yours.
« Reply #372 on: July 03, 2023, 11:46:08 AM »
Nice work!
The oil hose leaking at the tank is VERY common on the 750K7/8 bikes (and F2/3). It seems to be related to the extra kink angle of the smaller oil tank where the hose must bend a bit to make its trip to the engine. When the rubber gets aged, it cracks at the crimp fitting, then weeps down the braided cover to drip off the engine-side fitting. While the F0/1 does it, too, it is slightly less of an angle in that frame, so it takes longer for the hose to crack, or it occurs after the oil tank gets removed and reinstalled (usually for engine R&R).
Online MauiK3
  • A K3 is saved
  • Old guy
« Reply #373 on: July 03, 2023, 02:37:26 PM »
Really nice bike!
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #374 on: July 03, 2023, 06:25:18 PM »
Welcome aboard Nick
I took you up and headed over to new members and introduced myself.  Should have done that right away but I was in the zone.
Initially I had no plans to do any kind of photoblog like this but you all have inspired me, especially those of you who helped me diagnose and work through my brake light issue today.  I will say the whole thing is pretty intimidating.  I know how to turn a wrench and generally how things should look, but how to get them there is a whole different thing.  But I think I am going to document it so I can maybe help someone else who knows just enough to get themselves in trouble (like me).  Besides this is supposed to be my retirement thing, might as well get started on it early and enjoy riding it when I retire!
