Author Topic: Seat restoration  (Read 17658 times)
Offline jwurbel
Seat restoration
« on: November 21, 2022, 03:30:26 PM »
Have 72 750 and trying to save the original seat pattern as was distinctive for only that year.  The chrome strip appears impossible to remove.  Anyone have any advice, short of replacing with a new aftermarket cover?
Re: Seat restoration
« Reply #1 on: November 24, 2022, 01:15:59 AM »
 I got nothing. I bought a few bikes and boxes of parts and was lucky to get a NOS K4 seat for my bike. More recently I got a NOS K2 seat the same way.
« Reply #2 on: January 12, 2023, 08:36:29 PM »
 What I do know is Avon skin so soft bath oil can restore a good seat if it hasn't cracked yet. My 69 was so hard if you pushed on a panel it only flexed at the seam. Now if you press on it your finger goes in the vinyl.
Online newday777
« Reply #3 on: January 13, 2023, 01:46:51 AM »
I've read the chrome strip was glued to the vinyl.
If your cover is cracked it's toast.
Stu
My current rides
Prior bikes....
Online BenelliSEI
  • 1969 cb750
« Reply #4 on: January 13, 2023, 05:28:36 AM »
Don.....did you just apply it directly to the vinyl? My ‘69 is the same, but no tears or damage.
Online newday777
« Reply #5 on: January 13, 2023, 06:40:38 AM »
Heat the seat to loosen it up and massage the skin so soft in.
« Last Edit: May 24, 2023, 07:08:59 PM by newday777 »
Stu
My current rides
Prior bikes....
« Reply #6 on: January 13, 2023, 06:45:36 AM »
What I do know is Avon skin so soft bath oil can restore a good seat...
And good for 54 other uses! Havent tried it on tires...
https://www.everythingunscripted.com/55-uses-for-avon-skin-so-soft/
« Reply #7 on: January 13, 2023, 02:55:09 PM »
 Yes, directly on. I use a small cloth and keep it just for SSS use, but I have also drizzled it right out of the bottle. It will soak into the driest areas and in a few minutes you can see where to re-apply it. It doesn't make the seat slick, I even put my original seat cover back on over a new foam.
 Any area that stays oily you can buff it off. It didn't save my gl1000 NOS seat though, it developed cracks in the seams. Maybe I didn't use enough since my bottle went empty.
Offline Kelly E
  • Geriatric Hooligan
« Reply #8 on: January 13, 2023, 05:42:47 PM »
Back in 2017 when I bought my 94' Kawasaki ZG 1000 Concours the seat had started turning grey and my mom was out of SSS. My buddy said to use SC-1 spray. I sprayed it and let it soak in a whole bunch of times until the SC-1 wouldn't soak in anymore. It saved the seat cover and I'm still riding on it. The best part is that it says "NEW BIKE IN A CAN" on the label. ;D I spray the front of the fairing, fork lowers, front fender and the front of the mirrors before I leave on a road trip and when I get home all of the bugs and crap wipes right off.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online BenelliSEI
  • 1969 cb750
« Reply #9 on: January 13, 2023, 05:47:27 PM »
Amazing! I’m patiently removing the cover, trying not to break any tabs or any trim. So far so good. I’ll try this stuff. There is one small area where a seam is starting to roll open. What’s your favourite glue?
Don...ever ordered the “red foam seat pad” from Yamiya?
Offline grcamna2
« Reply #10 on: January 13, 2023, 05:59:12 PM »
Kelly, SC-1 ?
75' CB400F/'bunch o' parts'
Offline Kelly E
« Reply #11 on: January 13, 2023, 06:25:47 PM »
It's a spray protective coating.
1983 Honda CB 1100F
Offline grcamna2
« Reply #12 on: January 13, 2023, 07:03:10 PM »
I'm interested to get some of that SC-1:is it okay on painted surfaces ?.
« Last Edit: January 13, 2023, 07:05:37 PM by grcamna2 »
Offline Kelly E
« Reply #13 on: January 14, 2023, 09:08:02 AM »
Yes
1983 Honda CB 1100F
