Author Topic: Rear Brake Stoplight Switch  (Read 1155 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: November 29, 2022, 09:50:14 PM »
Bike is a 1977 Honda CB750 K. Too much to list as far as what's been done, but the for the sake of this question I pose, I'll say I've went ahead and bought the rearset from CognitoMoto, and unfortunately I have to figure out my own custom mounting for the 77-78 (my bike), for this rear brake stoplight switch.
I'm curious is anyone has had any experience with this and what are some solutions to this.
I'm also curious as to the inner workings and how exactly the rear brake stoplight switch operates - how is the spring, or whatever, relaying an electrical signal to the main box indicating the brake has been applied thus lighting up the rear brake light??
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Re: Rear Brake Stoplight Switch
« Reply #1 on: November 29, 2022, 10:09:38 PM »
Spring is attached to pedal and pulls down the spindle of the switch when pedal moved down this connects the two wires going to the switch which puts the light on.
Black is power in when key in on position
Yellow/Green is connected to bulb via loom
Offline Ellz10
  • ZZ
« Reply #2 on: November 30, 2022, 08:26:35 PM »
I thought the bottom of the spring is just attached to that little nub that juts out of the frame right there?
Offline stocky
« Reply #3 on: November 30, 2022, 09:13:37 PM »
the end of the spring attaches to the brake pedal like bryanj mentioned. pulling down the spring closes the circuit and sends a signal to the brake light. I personally took mine off for a cleaner look on my cafe. I never just use my rear brake without my front brake anyway, so it's fine for me.
« Reply #4 on: November 30, 2022, 11:11:12 PM »
If the switch body and the spring both connected to the frame how did you think it would work?
« Reply #5 on: December 01, 2022, 02:25:40 AM »
I used hydraulic switches on Red, it's cleaner solution.
Offline newday777
« Reply #6 on: December 01, 2022, 04:40:11 AM »
But there's no hydraulic on the rear drum brakes this is about.....
Stu
My current rides
Prior bikes....
Offline Ellz10
  • ZZ
« Reply #7 on: December 01, 2022, 11:55:28 AM »
Thank you to all the replies. For some reason I just could not see it in my mind - how it functioned, that is. Brain fart I suppose. The knowledge is much appreciated.
« Reply #8 on: December 01, 2022, 12:29:30 PM »
Rarely do i dissagree with tt but this time he has it wrong, the switches are on the power in side and the bulb is groubded via the casing
« Reply #9 on: December 01, 2022, 09:07:32 PM »
You are correct.
« Reply #10 on: December 01, 2022, 10:09:56 PM »
We all get it wrong sometime, and old boss of mine used to say "him that makes no mistakes does nothing"
Offline Kelly E
  • Geriatric Hooligan
« Reply #11 on: December 02, 2022, 09:35:24 AM »
That's a good one. ;D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #12 on: December 02, 2022, 01:06:03 PM »
For some reason I just could not see it in my mind ...
I used an aftermarket spring on my K3, sorry, I dont recall where I got it.
