Author Topic: 1973 CB750 Rescue  (Read 5055 times)
Offline j343my
Re: 1973 CB750 Rescue
« Reply #75 on: March 07, 2023, 02:55:56 PM »
Coming along nicely.  Go for the helmet mount but get good documentation! Pictures are a must have!
Thanks!
When I was taking apart the front fender, one of the fender stay grommets completely disintegrated.  I dug through my box of wire grommets and found one that was pretty much the exact size.  The outer diameter is a little smaller, and I had to sand it down a bit to make it thinner.  I'll probably replace all 4 at some point but for the time being it worked perfectly:
FYI...... I’ve noticed that vintagecb750.com is selling fender mounting hardware now. Looks like they have yours.
I did see that.  I don't really want to buy the hardware too just to get the grommets.  Also, interestingly my fender stays have shoulder bolts and flat washers, as opposed to the regular bolt and shoulder washers.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #76 on: March 08, 2023, 04:01:34 AM »
Following with interest.  Coming on well  :)
« Reply #77 on: March 09, 2023, 11:23:50 AM »
Making good progress, looks good too!  Hope that 3.5" tire doesnt rub, is the fender on yet?
What is that other bike in your garage, a Kawasaki? The grab bar looks familiar.
Offline j343my
« Reply #78 on: March 10, 2023, 09:28:47 AM »
Thanks!
Thanks!  The fender is on now and there is plenty of clearance for the 3.5" tire.  The bike with the grab bar in the background is an '84 XS650.  I also have a '74.
Offline j343my
« Reply #79 on: March 12, 2023, 01:38:51 PM »
Got a bit more done this week.
I cleaned up the rear fender, grab bar, turn signals, and tail light.  I wasn't planning on doing that just yet, but I have been cleaning up the chrome on other parts as I went along and they looked so bad in comparison.
Also the bolts that hold the front turn signals to the stalks were mismatched and it was really bothering me.  As an added bonus I found the turn signal bolt had been swapped with one of the rear fender bolts.
Before with turn signal bolt circled in red:
After with matching bolts:
Next I went back to the gas tank which is becoming the bane of my existence. I have managed to remove most of the rust, but I'm still dealing with some varnish/rust sludge at the bottom of the tank.  I wanted to remove the petcock before resorting to more drastic measures.
The petcock screws absolutely would not budge, even with an impact driver.  I decided to drill off the screw heads and just pull the petcock off.  After drilling off the heads, it still would not budge. I drilled a tiny bit further and realized the screw threads were completely packed with varnish.  Gluing the petcock to the screws:
I added a few drops of acetone to the screws and picked away at it with a pin.  I repeated the process for about an hour and finally...
Success:
Luckily the screws came out pretty easily after that with some channel locks.
The game plan now is to add some acetone or lacquer thinner to the tank with an old bike chain and see how that goes.
« Reply #80 on: March 12, 2023, 02:48:45 PM »
Acetone will destroy your paint, so if you are not planning on repainting be very careful...
Warm up the lacquer thinner and see if a warm batch softens the junk in the tank...
« Reply #81 on: March 15, 2023, 07:14:10 AM »
Thank your lucky stars that you were able to remove the petcock screws!
Hows the inside of the tank look? If rusted, EvapoRust may be a better option.
Offline j343my
« Reply #82 on: March 17, 2023, 01:53:05 PM »
The inside of the tank is pretty bad.  I tried EvapoRust initially after I rinsed it out.  That did a very good job on all the rust.  What I didn't realize was how much varnish was at the bottom of the tank.  I have lacquer thinner in it right now which seems to be doing a pretty good job of dissolving the varnish.  I'll probably put the EvapoRust back in once I take out the lacquer thinner.
« Reply #83 on: March 17, 2023, 03:16:02 PM »
Warm evaporust works best... So, keeping the tank warm while derusting is always a good idea.
« Reply #84 on: March 17, 2023, 03:18:32 PM »
A black painted cardboard backstop if a tank is sitting in the sun will gain radiator effect...
People living in the desert quickly realize how dark clothing and the heat of summer do not mix well. I tend to reserve my dark colored clothing for wintertime.
Offline j343my
« Reply #85 on: March 18, 2023, 02:19:31 PM »
I had the tank with EvapoRust in the house.  Best I could do being in Canada in the winter.
Offline j343my
« Reply #86 on: March 24, 2023, 04:21:53 PM »
Lots more progress recently.
Cleaned up the exhaust.  Other than the surface rust it is actually in pretty good shape. No holes anywhere.
Before:
After:
Also did a full engine tune up.
- Cleaned and lubed the advancer
- Set the points gap
- did static timing
- set cam chain tension and valve tappet clearances
Checked the spark plug caps next.  The cap on cylinder one basically just fell off when I took off the rubber boot.
3 of the caps were around 9-10 kΩ, but this one was the winner:
So I replaced them along with the spark plugs.  It had D7EA plugs.  I replaced them with D8EA.
Then I fired her up, set the idle, did the timing, and synced the carbs:
Also my sluggish tach seems to have righted itself.  I guess it just needed to shake off the cobwebs.  Its now moving as it should.
Made a bit more progress with the tank also.  The lacquer thinner appears to have done a good job dissolving the varnish.  I can actually see the bottom of the tank now.  After rinsing thoroughly, I put the EvapoRust back in to hopefully finish the job.
Offline grcamna2
« Reply #87 on: March 24, 2023, 05:53:30 PM »
Those pipes turned out Excellent  8)
Offline BenelliSEI
  • 1969 cb750
« Reply #88 on: March 29, 2023, 03:28:07 PM »
Moving right along! Nice work.
Online denward17
« Reply #89 on: March 29, 2023, 06:40:59 PM »
How did you get all the rust off the exhaust pipes?
« Reply #90 on: March 29, 2023, 06:59:39 PM »
Brasso and 0000 steel wool can work as can phosphoric acid...
Nice Jardines exhaust...
Offline j343my
« Reply #91 on: March 31, 2023, 05:34:09 PM »
Thanks guys!
A damp blue scrubbing pad got the majority of the rust off.  I used some wadded up tinfoil to get the more stubborn areas.  Then I just gave it a good polish.
Offline j343my
« Reply #92 on: April 28, 2023, 04:38:55 PM »
So my gas tank struggles continued.  I finally got the varnish and rust out, and back on the bike.  I filled the tank with gas, and when I came back a little later I was greeted with a small puddle of gas on the ground.  It turned out there was a pin hole in the side of the tank.  I drained it, and ordered the POR-15 kit.  In order to do the degreasing and acid etching I super glued the hole from the outside:
Thankfully that worked and I was able to get the tank lined:
and with that done, I had a rideable bike:
She turns 50 this month, so my goal was to get her out on a ride to celebrate.  The weather cooperated yesterday so we went out for a quick spin.  She shifts through all the gears and runs pretty good for a bike that hasn't stretched its legs in over three decades.
A few challenges remain:
- doesn't really like to idle around 900 rpm.  It will idle fine a little over 1000, but below it sounds like its really struggling and eventually stalls.
- the clutch is still rattling quite a bit.  The carbs have been sync'd but that didn't fix the problem.
- the petcock is leaking and carb no. 4's float needle doesn't seem to seal completely so about once a day it spits fuel out the overflow.  I tightened the petcock screws a bit more, and that seems to have solved the petcock leaking.
Online denward17
« Reply #93 on: April 28, 2023, 05:21:19 PM »
It's great you were able to get a ride in, looking good.
Offline BenelliSEI
  • 1969 cb750
« Reply #94 on: May 05, 2023, 02:48:40 PM »
That has turned into a fine looking ride! Did you use the fibre washers under the heads of the petcock screws? Without them it will drool forever. I always let my bikes idle where the rattle disappears. The tach is not that accurate. If it likes 1,000 rpm, just leave it there. All my 750’s creep higher as they really warm up. You’ll get good at just setting it up or down with a glove, from the seat! Congrats.
Offline bek1966
« Reply #95 on: May 06, 2023, 09:45:28 AM »
Great looking results. Nice work!
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
Pleasant Prairie, Wisconsin
Offline grcamna2
« Reply #96 on: May 06, 2023, 10:39:09 AM »
I like the look of the inside of your fuel tank: Sweet  8) 8)
Offline willbird
« Reply #97 on: May 07, 2023, 07:56:45 AM »
In the 1970's somebody stole my bike when it was my dads (he bought it new in 72). They took it down the street to a car dealer and stole tank and side covers. He bought a used tank from the "trading post" weekly newspaper. It was the color your bike is. He never did find new side covers. My bike went that color for a decade :-). It is one of the 3 colors my bike has been LOL.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #98 on: May 07, 2023, 07:59:36 AM »
green is good!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline j343my
« Reply #99 on: May 09, 2023, 05:30:15 PM »
Thank you!
Thanks!  I used new fibre washers.  It turns out I just didn't tighten the screws enough.  I opened up the petcock and cranked them down harder and it stopped leaking.  Thanks for the idle tips.  I'm going to have to play around with that a bit more.
Thanks!
Thanks.  The tank was my biggest struggle with this bike.  Hopefully that's the end of my tank problems.
