Author Topic: Old Shop Tools.  (Read 617 times)
Offline BenelliSEI
  • 1969 cb750
Old Shop Tools.
« on: December 04, 2022, 11:17:20 AM »
Share some of your favourites?
This ancient valve spring compressor is operated by the lever, opposite the spring retaining arms. It was given to me by a retiring machinist in the early ‘70’s, so not new! He probably used it for +40 years in the engine rebuilding shop where he worked. He was well known for rebuilding FORD Model T and A engines. I used to buy parts there, when I was a kid and pestered the guys endlessly. I borrowed it so often, he gave it to me on his last day. Makes me smile, whenever I use it. It’s probably +80 years old.
As you crank the rotating lever, it drives down the arm that pushes on the valve “hat’. The arm is serrated and is locked in place by the small, sprung lever (a bit like the mechanism on a come-along winch). To release, you apply some extra pressure and lift off the locking lever.....  The gear teeth are very worn, so  it’s a bit dodgy.
« Last Edit: December 05, 2022, 09:40:54 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
Re: Old Shop Tools.
« Reply #1 on: December 04, 2022, 11:22:58 AM »
Previously posted, but good example: Original, factory Honda sync tool. They don’t work, but cool “wall art” in my shop...... what have you got?
Re: Old Shop Tools.
« Reply #2 on: December 04, 2022, 11:26:07 AM »
 Some of these are old ford model A, T, and flathead tools.
Offline BenelliSEI
  • 1969 cb750
Re: Old Shop Tools.
« Reply #3 on: December 04, 2022, 11:29:22 AM »
Last one for me..,.. Original spark plug wrench from my Benelli SEI tool kit. Fits easily down every hole in a cb750 and has a twisting arm that’s long enough (and shaped cleverly enough) to actually work!
Offline CycleRanger
  • No comment about being an
Re: Old Shop Tools.
« Reply #4 on: December 04, 2022, 03:32:58 PM »
I think my gauges are even older and they still work!
Re: Old Shop Tools.
« Reply #5 on: December 04, 2022, 03:52:09 PM »
Don, what are those plyers in the middle for?  I have a set of those that were inherited from my mechanic grandfather and still have not figured out what they are for?
Offline BenelliSEI
  • 1969 cb750
Re: Old Shop Tools.
« Reply #6 on: December 04, 2022, 03:59:17 PM »
Nice!
Re: Old Shop Tools.
« Reply #7 on: December 05, 2022, 07:47:27 AM »
Mine still work as well...
Offline BenelliSEI
  • 1969 cb750
Re: Old Shop Tools.
« Reply #8 on: December 05, 2022, 07:50:37 AM »
Wow..... I’ll have to stick some hoses on mine and try again!
Offline rocket johnny
Re: Old Shop Tools.
« Reply #9 on: December 05, 2022, 08:23:29 AM »
i think what sean is looking at is a valve spring compressor for use on flat heads .
