Author Topic: carb bowl drain screw position  (Read 391 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: December 08, 2022, 07:26:43 AM »
I dont know a lot about carbs, but I noticed that the drain screws on 1-3 face left and 4 faces right.
Can the bowl be turned around by accident on number 3? Will this mess up the float?
Is that maybe why my number 3 lets out gas on the overflow?
JD
1975 CB550K1
Offline BenelliSEI
  • 1969 cb750
Re: carb bowl drain screw position
« Reply #1 on: December 08, 2022, 08:01:29 AM »
All four bowls should have the screws facing to the outside. 1 and 2 are a pair and 3 and 4 are the opposite. They can only face one way.
« Last Edit: December 08, 2022, 08:46:13 AM by BenelliSEI »
Offline carnivorous chicken
« Reply #2 on: December 08, 2022, 08:16:49 AM »
Someone has most likely replaced the #3 carb bowl with a #1 or #2. I don't think it will make a difference, it's just a matter of making it a little more difficult to drain that carb if need be.
Offline Deltarider
« Reply #3 on: December 08, 2022, 08:24:47 AM »
[...] I don't think it will make a difference, it's just a matter of making it a little more difficult to drain that carb if need be.
Nonsense, of course it makes a difference.
CB500K2-ED Excel black
Offline Deltarider
« Reply #4 on: December 08, 2022, 08:26:42 AM »
Ofcourse it lets out gas and most probably not only from the overflow...
The front and rear of the floatchamber is not the same.
« Reply #5 on: December 08, 2022, 08:40:37 AM »
Depends on year and model of the bike, I suppose, which wasn't stated. I've had bikes with replaced float bowls and it made no difference.
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: December 08, 2022, 08:42:50 AM »
Whoa!.... Assuming this is a SOHC cb750? Any floatbowl can be on any carb and the screw can point in the opposite direction. They can NOT be rotated 180 degrees, but are interchangeable. If not, how can he have one mounted?
The overflow leaks if the float level is too high, float valve leaking, punctured float, or tube is cracked.....
« Last Edit: December 08, 2022, 08:47:28 AM by BenelliSEI »
Offline JDrider
« Reply #7 on: December 08, 2022, 11:07:58 AM »
to be clear, none of the float bowls are on backwards, number three just has a bowl that faces to the left instead of the right.
JD
1975 CB550K1
Offline JDrider
« Reply #8 on: December 08, 2022, 11:10:48 AM »
I'm guessing this is the case.
JD
1975 CB550K1
Offline Deltarider
« Reply #9 on: December 08, 2022, 11:46:04 AM »
Apologies, I've messed up. I read it as if it was suggested to have the drain screw on the correct side by turning the bowl 180 degrees. Sorry, for the confusion.
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: December 08, 2022, 12:06:01 PM »
I have a few like that too. I usually drain them by popping the retaining clip anyway.
Offline JDrider
« Reply #11 on: December 08, 2022, 12:20:41 PM »
I think I initially was thinking this until I realized that the drain tube would be on the other side and I knew that wasn’t the case.
JD
1975 CB550K1
