Author Topic: cb650 Timing Chain Tensioner lower screw  (Read 1010 times)
Offline Cozy
« on: December 08, 2022, 03:33:57 PM »
Hey All,
Can't find any topics on this specific issue so was wondering what y'alls thoughts are. My cam chain tensioner lower screw is unthreaded, is there a way to push this back in without having to take the cylinder heads and jugs out?
Have some pictures attached.
Offline scunny
  • don't call me expert
Re: cb650 Timing Chain Tensioner lower screw
« Reply #1 on: December 08, 2022, 04:02:35 PM »
You should be able to remove the center head cover and reach down with a large screwdriver and press it back out.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline fizzlebottom
« Reply #2 on: December 09, 2022, 09:41:19 AM »
You might be able to do something like get a strong magnet on the end of the bolt and pull it back through. Or superglue, but very carefully.
If you can't somehow coerce it out that way, you will probably have to at least get the cylinder head cover off in order to access the tensioner. Last time I had my 650 apart, I don't recall there being enough access with just center valve cover off.
But unless something is really wrong, I'm unsure how it worked its way inside like that. The few ways I can think of this happening are: broken bolt, improperly installed tensioner during rebuild, or broken / jammed tensioner.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
Offline Cozy
« Reply #3 on: December 09, 2022, 11:00:34 AM »
For future reference, I was able to get the screw out by using a neodymium magnet. I took off the carbs, stuck a 30 pound magnet on (thank god the block is aluminum) and pulled it out with the nut attached to the magnet, screw it in enough to get it on the thread, and tightened it with the 10MM from there.
