Author Topic: CL350 kickstarter problem  (Read 1530 times)
Offline billdramp
  • DOOMTOWN RIDERS / PORTLAND, OR.
« on: March 09, 2007, 01:49:42 PM »
My kickstarter is not engaging all the time.
Just started doing this... sometimes it just spins, and does not seem to catch any gear teeth.
Other times it works fine.
Anyone had this problem, and or know where to start trouble shooting.
ALL help is appreciated.
Cheers from Portland,
Billy
1975 CB750K (daily rider), 1974 CB550K (sold), 1974 CL350 (sold), 1973 CL350 (when I get around to it...), 1971 CB750 (in boxes), 1978 CB750F in boxes, 1976 CB750F SUPERSPORT (sold), 1975 CB400 FOUR (crashed), 1976 400 FOUR (work in progress), 1977 cb400f
SOHC4  MEMBER #1527
Offline Raul CB750K1
Re: CL350 kickstarter problem
« Reply #1 on: March 10, 2007, 12:41:56 PM »
Offline billdramp
« Reply #2 on: March 10, 2007, 03:19:07 PM »
Thanks Raul,
Good thread... I guess I will take a stab at repair this weekend.
Billy
SOHC4  MEMBER #1527
« Reply #3 on: March 14, 2007, 03:08:15 PM »
Ooops, I just read "starter" and inmediately thought about the electric. Why would the kickstarter give any trouble at all?
As dgfischer pointed out, the kickstarter has a spring that presses a serrated tooth wheel against the gear wheel. When the kickstarter is at rest, another indentation in the oil pan fully disengage the gear wheel to the kicstarter wheel. When you kick it, the spring presses against the gear wheel but if the engine start to run, the orientation of the tooth makes them to spin and not catch the kickstarter wheel, I don't know if I have explained myself well. So you either have worn wheels, or spring not fully strong.
Now the bad news: you will have to take the engine out, turn it upside down and remove the lower cranckase to service the kickstart.
