Author Topic: CB550 heavy clutch pull  (Read 560 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: December 14, 2022, 05:23:27 AM »
Hi Guys,
I got this bike (cb550k1) a few months ago and after seeing photos of cb550s, my clutch cable seems too long.
Also its a hard pull also. I attached a photo of how the cable is sticking out. Its routed with the other cables on the right under the tank.
I think previous owner bought wrong length cable?
Anyone know the best place to get correct cable?
or can I use this?
Thanks.
JD
1975 CB550K1
Online jlh3rd
Re: CB550 heavy clutch pull
« Reply #1 on: December 14, 2022, 06:07:48 AM »
the cable routing is technically for a 550 F....but it should be the same for the clutch cable...
A hard to pull clutch can be caused just from an old dirty cable.....
Online jlh3rd
« Reply #2 on: December 14, 2022, 06:09:23 AM »
s
Offline JDrider
« Reply #3 on: December 14, 2022, 06:10:11 AM »
I was told it was a new one.
JD
1975 CB550K1
Offline Shtonecb500
    • Youtube profile
« Reply #4 on: December 14, 2022, 06:28:45 AM »
It’s too long and if it’s pulling hard just replace it, they are cheap…or find a local shop that will shorten it for you.
edit: nice bike.
« Last Edit: December 14, 2022, 07:29:34 AM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline JDrider
« Reply #5 on: December 14, 2022, 06:50:17 AM »
https://www.davidsilverspares.com/CB550K1-1975-USA/part_70439/
I found this one. I'll give it a try.
It’s too long ans if it’s pulling hard just replace it, they are cheap…or find a local shop that will shorten it for you.
JD
1975 CB550K1
« Reply #6 on: December 14, 2022, 08:23:23 AM »
Hard to tell from the pic, are those the stock handlebars?
Offline JDrider
« Reply #7 on: December 14, 2022, 08:24:27 AM »
Yes
JD
1975 CB550K1
« Reply #8 on: December 14, 2022, 08:39:02 AM »
The more bends in the clutch cable the more friction it will have.  But a hard pull can also stem from improper adjustment at the pivot arm at the clutch, or too stiff spring in a replacement clutch.  Barnett was famous for this.
Offline newday777
« Reply #9 on: December 14, 2022, 08:40:19 AM »
Yes the cable is too long for those bars.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #10 on: December 14, 2022, 08:41:32 AM »
Yes
Post a picture from the seat
Stu
My current rides
Prior bikes....
Offline JDrider
« Reply #11 on: December 14, 2022, 08:44:46 AM »
this is all I have
Yes
JD
1975 CB550K1
