Author Topic: What’s the difference between these cylinders??  (Read 676 times)
Offline CB750R
  • 77 CB750F
« on: December 16, 2022, 07:37:23 AM »
I keep reading on compatibility of heads/cylinders etc… I have my parts bike F2 motor torn down as well as my “K5” I built with Random EBay’d head and cylinders many years ago. I have both sets of cylinders cleaned up. And I can’t see why these can’t be swapped. The F2 cylinders have a cracked fin which is why I want to swap parts.
Re: What’s the difference between these cylinders??
« Reply #1 on: December 17, 2022, 04:23:01 AM »
78F cylinders have stud holes are open in front - two of them I believe.
I quess it depends what year is the F2.
Offline CB750R
  • 77 CB750F
« Reply #2 on: December 18, 2022, 08:34:09 AM »
Here is a clear answer to the question. It turns out in my case I’ve been using a set of f2 cylinders in my k engine for 12+ years.
Link to the answer is below:
https://www.cb750.com/threads/f2-750-head-and-barrell-identification.3419/?fbclid=IwAR0sM0Ap14TAzOS10w21jQByjeJuuEV_S39S8D8C6lrJ9HNFR4kJODzLYb4
Offline CB750R
  • 77 CB750F
« Reply #3 on: December 18, 2022, 08:37:34 AM »
From that post above the head differences:
« Reply #4 on: December 18, 2022, 04:12:56 PM »
 I think to use the k cylinder between an F crankcase and F head will just leave the extra oil passage sitting unused. A K head and K cylinder may require the oil passage in the top of the F crankcase to be opened up to allow both oil returns to drain.
Offline 34barab
« Reply #5 on: December 18, 2022, 05:23:21 PM »
Reason being so there's more oil longer on the valve train?
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Online HondaMan
« Reply #6 on: December 18, 2022, 07:42:19 PM »
Over the years, some have argued that be the point.
Personally, I think Honda was trying hard to save the last Yen on the castings, as the F2/3 was their riskiest build of the 750 and it was not at all certain that it would sell very well, given the track record of the F0/1 bikes. So, it was a stepchild in the Engineering Group. I believe some of the original 750K0 designers were called in to help work on it, and their designs were 'overruled' in the top end springs' retainers (which would have been custom parts) in favor of some common stamped-steel automotive retainers, suitable for 6300 RPM top speed. That became the Achilles' Heel of the whole F2/3 design in the end, and how many of them died.
