Author Topic: Front brake Caliper - 80’ CB650C  (Read 404 times)
Offline MTNman
« on: January 09, 2023, 03:54:05 PM »
Hey guys;
I was rebuilding the front brake Caliper on my subject bike, and I ran into an issue.
The piston is just stuck solid in the housing…. Anyone have any good tricks to remove it? Or is it a “replace” issue.
Any help is appreciated, thanks in advance.
Re: Front brake Caliper - 80’ CB650C
« Reply #1 on: January 09, 2023, 04:10:20 PM »
Remove the caliper but leave the bleed nipple in and done up.
On your gease gun(of course you have one!) Unscrew the zerk fitiing from the flexible or steel pipe, GENTLY start to screw the caliper hose fitting remale hole onto the grease gun pipe NOTE CAREFULLY the threads are different and so will only go approx 2 turns DO NOT FORCE IT or you will wreck the caliper.
Pump the grease gun that you filled before you started and the piston will come out
Next spend many happy hours degreasing the caliper, remove the seal and de #$%*e the seal groove
Offline MTNman
« Reply #2 on: January 09, 2023, 04:40:00 PM »
Could this be potentially done by hooking it back up to the brake handle and pump brake fluid through until it comes out? To prevent possible damage?
Offline Mark K
« Reply #3 on: January 09, 2023, 06:21:36 PM »
I had a similar issue, but was not able to put it back on the bike to try to use brake fluid pressure to try to get it out.
Here's a link to an area on the forum that might be helpful. http://forums.sohc4.net/index.php/board,136.0.html
Good luck to you.
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline MTNman
« Reply #4 on: January 09, 2023, 09:44:52 PM »
Good luck to you.
That helps a lot, thanks a bunch.
« Reply #5 on: January 09, 2023, 11:52:15 PM »
Yes, if you master cyl works and you can bleed the system
« Reply #6 on: January 10, 2023, 07:05:00 AM »
There is also the "compressed air trick" which can be more fun and less messy that the "grease gun trick", albeit a little dangerous!
« Reply #7 on: January 10, 2023, 07:22:49 AM »
Compressed air frequently fails, never had grease gun fail yet, biggest mistake of most people is removing caliper before using master to pump piston out
Offline Godffery
  • Godffery's Garage
« Reply #8 on: January 10, 2023, 06:17:51 PM »
 I've got a rebuilt one if you want to go that rout.
Offline MTNman
« Reply #9 on: January 12, 2023, 05:17:20 PM »
Yep I made that mistake as well, and I also tried the compressed air procedure as detailed in the service manual. It didn’t work for me either.
So far I’m working on getting new seals to pump out the cylinder. The front brake was super rough when I bought the bike.
Offline MTNman
« Reply #10 on: January 12, 2023, 05:18:37 PM »
I’ll keep that in mind if something goes very wrong lol. Thanks!
