Author Topic: 1978 Kawasaki KL 250  (Read 3599 times)
Offline Kelly E
  • Geriatric Hooligan
Re: 1978 Kawasaki KL 250
« Reply #25 on: May 04, 2023, 04:06:42 PM »
Today we finished sanding the frame. After Paul left I made and welded on a piece to strengthen the rear rock guard mounting bracket. It was just a piece of strap with a hole in it. I added another piece to the back edge so it doesn't just bend upward when it takes a hit.
« Last Edit: May 04, 2023, 04:08:22 PM by Kelly E »
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Kelly E
« Reply #26 on: May 05, 2023, 01:47:10 PM »
Today I made the rest of the rock guard. I need to put the motor in one more time to make sure the drain plug access hole is in the right spot.
« Last Edit: May 05, 2023, 01:49:08 PM by Kelly E »
1983 Honda CB 1100F
Offline grcamna2
« Reply #27 on: May 05, 2023, 01:50:29 PM »
That one at the bottom will certainly protect the engine cases.
Offline BenelliSEI
  • 1969 cb750
« Reply #28 on: May 05, 2023, 02:38:32 PM »
Nice work!
Offline Kelly E
« Reply #29 on: May 19, 2023, 02:59:37 PM »
Today we got the frame painted. We painted it in the new shed on the back of the shop. It was way easier to see what I was doing and the paint didn't turn to dust before it hits a nearby frame tube like it does in the direct sunlight. 8)
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #30 on: May 21, 2023, 05:27:50 PM »
Looking good! This will be a fun ride!
Offline Kelly E
« Reply #31 on: July 23, 2023, 09:55:47 AM »
Yesterday we installed the motor in the frame and assembled the triple tree. I had to enlarge the hole in the rock guard I made on the bottom. The hole for the drain plug was too small and too far back. After that I had to touch up the bed liner.
1983 Honda CB 1100F
Offline grcamna2
« Reply #32 on: July 23, 2023, 10:35:16 AM »
Progress  8)
Offline BenelliSEI
  • 1969 cb750
« Reply #33 on: July 23, 2023, 11:10:09 AM »
Going to be a good bike!
« Reply #34 on: July 23, 2023, 02:18:54 PM »
Is the son chomping at the bit for the bike to be finished?
Offline Kelly E
« Reply #35 on: July 23, 2023, 02:37:08 PM »
Sort of, he has a girlfriend now so he's "busy". 8)
1983 Honda CB 1100F
Offline grcamna2
« Reply #36 on: July 23, 2023, 04:43:44 PM »
I hope you get the passenger pegs on the bike.. for later.
Offline Kelly E
« Reply #37 on: July 31, 2023, 03:04:54 PM »
Today I got a few more parts installed. I'd better get the wiring harness cleaned up soon, it's time to install it.  8)
1983 Honda CB 1100F
Offline grcamna2
« Reply #38 on: July 31, 2023, 06:15:43 PM »
The rear shocks look good.
Offline Kelly E
« Reply #39 on: September 04, 2023, 03:44:09 PM »
Today we worked on rounding up decent hardware to put stuff back together. It was a hodge podge of hardware already so we dug into the stash and used what worked. I did a lot of trimming bolts to the correct length.  Now there's quite a bit of Honda hardware on this Kawasaki.
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #40 on: September 04, 2023, 05:00:09 PM »
That is looking very nice!
Offline Kelly E
« Reply #41 on: September 19, 2023, 03:39:02 PM »
Today I got some stuff done on the KL250. The missing seal for the sprocket carrier came in so I installed it. Then I tackled the messy job of lubing all 7 of the control cables. I realized I needed to get the rear brake cable installed before the rear wheel just because it will be easier.
1983 Honda CB 1100F
Offline Kelly E
« Reply #42 on: September 30, 2023, 04:19:54 PM »
Today we got more done like the kickstand, exhaust pipe, rock guard, gauges, foot pegs, airbox and battery/electrical stuff. We took the front fender back off because I forgot to mask and spray the bottom side with bed liner.
We also got a few more bits and pieces ordered like handlebars and grips. I need to remove the gauges to blast and paint the guage/ headlight mount. CRS(can't remember #$%*) strikes again. 8)
1983 Honda CB 1100F
Offline grcamna2
« Reply #43 on: September 30, 2023, 04:42:33 PM »
Kelly,this KL250 project is coming along well;I like the custom bend to the head-pipe.
Offline Kelly E
« Reply #44 on: October 14, 2023, 01:42:43 PM »
Today we got the exhaust system finished. The muffler seems a bit long but we can find another one after the boy thrashes this one. I have everything else ready to install the headlight bucket and wiring. Then install the bar controls so I can put the headlight in. Also finish up the cable routing brackets and clean out the gas tank.
It's almost done and then I can go see how long the 30 year old tires last. 8)
1983 Honda CB 1100F
Offline grcamna2
« Reply #45 on: October 14, 2023, 01:55:54 PM »
Kelly,the custom exhaust you fabricated reminds me a little of a Kawasaki 1400 Concours style.
The bike is looking good.
Offline Kelly E
« Reply #46 on: October 14, 2023, 02:59:08 PM »
Yeah it does have that potatoe launcher look. 8)
That's what you get when building stuff from scrap. ;D
1983 Honda CB 1100F
Offline grcamna2
« Reply #47 on: October 14, 2023, 04:26:30 PM »
The exhaust cannon  :D
Got a 'Rad' look to it.
Offline Kelly E
« Reply #48 on: October 22, 2023, 08:16:06 AM »
Yesterday we went through the handlebar controls to clean up the switches and get some fresh dielectric grease in them.
1983 Honda CB 1100F
Offline Kelly E
« Reply #49 on: October 29, 2023, 08:40:16 AM »
Yesterday we started to deal with the gas tank. There's no visible signs of it leaking but the PO tried to line the tank with what looks like fibreglass resin. It's already peeling and we got a bunch of it out with a long pick. Then we poured in some acetone and walked away.  >:(
1983 Honda CB 1100F
