Author Topic: Changing wheel bearings?  (Read 2045 times)
Offline Magpie
« on: January 22, 2023, 08:37:33 AM »
Do you automatically change the wheel bearing when doing a restoration of these old bikes? Mine seem do to be good, no noise and no play but they are 50 years or so old.
Cliff.
Offline BenelliSEI
  • 1969 cb750
Re: Changing wheel bearings?
« Reply #1 on: January 22, 2023, 08:51:23 AM »
Cliff.
[/qu
Cliff... Good Question. Interested what everyone else says too. On my current project (1969 cb750, 17,000 miles), all the rear bearings were undisturbed, originals. None were shielded, so I popped them out, cleaned out all the dried, old grease, and they seemed perfect. Repacked them all with fresh grease, all new seals, and back they went. At the front, I had a new set sitting on my shelves, so just replaced them..... I did keep the originals, because they too seemed just fine.
« Reply #2 on: January 22, 2023, 08:54:59 AM »
Quality sealed bearings have very long life span.   I had pair failed on me - it got kinda loose - but they were cheapos from ebay.
I would keep them in if they look/feel good.
« Reply #3 on: January 22, 2023, 09:09:24 AM »
If wheel is off you can test to rotate wheel on axis and also rotate bearing with finger. It should not feel like sand inside.
I replaced wheel bearings on my CB750 K6 before mid 80's. I had acess to a press at my job to do it correctly.
Mostly long tourings after maybe 40.000 km.
Bike parked 20 years in barn.
Bearings did not feel good when I restored bike.
Replaced them all. SKF 2RS as before.
I think that parked for long period might not be good for bearings.
Last wheels got SKF 2RSH with even better seal according to the manufacturer description.
Offline CycleRanger
  • No comment about being an
« Reply #4 on: January 22, 2023, 09:24:44 AM »
I always replace the wheel bearings.  They're relatively inexpensive and simple to install.
Offline Magpie
« Reply #5 on: January 22, 2023, 09:53:29 AM »
Thanks guys, good comments. Cliff.
Offline newday777
« Reply #6 on: January 22, 2023, 09:54:05 AM »
The old grease in them as John has said is the problem that needs addressed even if the bearings are still good, so the stay good, so either you clean out repack the bearings with fresh grease or take your chances on new bearings having enough grease in them(aftermarket bearings are known for having little grease in them).
Grease lubricates and cools the bearings.
Stu
My current rides
Prior bikes....
Offline Johnie
« Reply #7 on: January 22, 2023, 10:56:17 AM »
You'll get a few different views on this subject. The old bearings are not sealed. Replace them as long as they're already out with new quality sealed bearings. Minimal cost involved. Like CyceRanger...I change front and back on all my projects. No sense in keeping 50 year old bearings in there. Peace of mind for sure.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: January 22, 2023, 12:11:46 PM »
Counter point: Make sure you buy SKF, FAG or quality bearings. I have bought kits from some of the suppliers we all use and they were so lousy I simply threw them out. When I buy any new bearings, I go the a bearing store (here Canadian Bearings is a well known spot) and buy across the counter. They don’t stock any junk.
Offline Honda Hansel
  • Sherwood Park AB
« Reply #9 on: January 22, 2023, 12:52:02 PM »
Hi
Wheel bearings are cheap that's correct
I also prefer good qualities when buying bearings
Brand names are all ways good to get and I look at it this way
If I can get bearings that is made in Japan that is not the regular brands then I'm fine with that
Japanese made parts are in general good quality
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
« Reply #10 on: January 22, 2023, 02:24:39 PM »
If you are the type of person to just ride your bike fast in all weather, never clean it, and are largely oblivious to signs of trouble as long as the damn thing still moves under it's own power...than yeah, you better replace them a hell of a lot more often than every 50 years.  I don't see anybody on this site behaving like that.  But there is little real reason to throw away perfectly good bearings.  It's easy to check rears every time you service your chain and that should remind you to check out the fronts too.  Fortunately, quality replacements are still widely available.  Not much point in chucking perfectly good old original bearings that usually still work fine and replacing with chinesium that is not gonna last.   And be careful buying from a bearing house.  Bearings come in a wide variety of tolerances for any given size.  Tighter tolerance may be better initially, but any contamination is gonna wreck it rapidly.  A looser tolerance may be damaged by impacts and side loads.  Just some of the reasons to confirm "If it ain't broke, don't fix it."
Offline Mark K
« Reply #11 on: January 22, 2023, 03:10:57 PM »
What are anyone's thoughts on sealed bearings from All Balls? I bought from them to replace old front and rear wheel bearings and replaced the steering stem ball bearings and races with tapered steering stem bearings from All Balls for my '73 750. Bike hasn't rolled anywhere yet except in the garage 😂
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline CycleRanger
« Reply #12 on: January 22, 2023, 03:21:00 PM »
I have used several sets of bearings from them. No issues.
I've also gotten bearings from the local bearing store.
The bearings in these bikes are standard sizes.
« Reply #13 on: January 22, 2023, 03:53:02 PM »
They are unpredictable.  All Ballz has apparently not manufactured a single bearing.  They are just putting together convenient kits, which is fine, if you actually need new bearings.  I have never seen the same bearing manufacturer (its always printed into the bearing, usually on the seal) twice and I have used lots of All Ballz steering head bearings.  So you never really know exactly what you are getting.  In my experience, with dozens of sohc4s, any bike with 10k miles on it usually needs steering head bearings and tapered rollers are just a more durable, less service demanding design.  As far as wheel bearings?  How will you know if what is in your All Ballz kit is gonna last longer than the likely good originals?  In my experience original wheel nearings are usually  ok.  Is two removeable seals even really an improvement? ...as removeable seals always have more drag and what is really gonna get in there anyway with just one during normal use?  Not to mention that very few of these bikes ever see a mud puddle again, let alone the kind of mileage that they may have seen in the first 50 years.  Also, every wheel bearing I have had to replace, was already replaced with something other than oem.  But of course, if your bearings don't roll smoothly...replace them!  And then, if you are actually gonna ride your bike, check them regularly.
Offline grcamna2
« Reply #14 on: January 22, 2023, 06:49:25 PM »
Wheel bearings are very important;I have been looking for better quality 'over he counter' bearings;the market is flooded with cheap China bearings..
I've lately been very pleased purchasing Nachi made in Japan bearings online. I would like to purchase fresh NTN made in Japan bearings 2RS type.
« Last Edit: January 22, 2023, 06:51:28 PM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline Steve_K
« Reply #15 on: January 26, 2023, 10:50:41 AM »
Several years ago, I had two 550's and when I pushed them around in shop, they took the same amount of effort to push.  Yes, the brakes were NOT dragging.  I replaced bearings on one and I was quite surprised how the new bearings made a such difference.  The other 550 got new bearings next.
Change them, they are old.
Steve
Steve_K
Online Remcod
« Reply #16 on: January 26, 2023, 02:04:26 PM »
I use allballs happy with them so far
Verstuurd vanaf mijn SM-A536B met Tapatalk
« Reply #17 on: February 28, 2023, 05:50:43 PM »
 If my bearings have removable plastic dirt shields and appear newer, I pop them off for a check. If they look and feel OK, I've been known to clean and re-pack them.
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: February 28, 2023, 08:42:37 PM »
+1. Done it and never been sorry. I suspect buying new bearings can lead to surprises. I have no problem cleaning and repacking a good quality part (on a bike showing reasonably low mileage).
