Author Topic: Rear sprocket  (Read 1579 times)
Re: Rear sprocket
« Reply #25 on: January 27, 2023, 08:36:38 PM »
JT brand sprockets are hobbed and milled/drilled,ive had them last ages and ages,as for big thumpers the KLR should have a rubber damped cush rear hub?my old TT600 had solid driven rear hub,pretty harsh,a mate with the later 660 Tenere has to replace the rear cush rubbers yearly!
« Last Edit: January 27, 2023, 08:38:50 PM by dave500 »
Offline BenelliSEI
  • 1969 cb750
Re: Rear sprocket
« Reply #26 on: January 28, 2023, 06:34:44 AM »
The KLR has big cush rubbers in the drive side, i’ll Look more closely this time. I think I used JT sprockets the last time and they did last longer then the OEM sets. I’m going to try the “old chain break in”. Sounds smart.
« Last Edit: January 28, 2023, 03:13:05 PM by BenelliSEI »
Re: Rear sprocket
« Reply #27 on: January 28, 2023, 03:03:50 PM »
A word of advice/experience:
All of the rear sprockets we see today are molded, not cut (if steel). This leaves a fine gritty surface in the teeth, which will wear off in 50 miles and then jam the new chain. This then wrecks the new sprockets, quickly.
To solve this: run the OLD chain on the NEW sprockets for 50-100 miles, first. Then install the new chain. You will get twice as much chain life from that chain if you do this simple 2-step dance.
Thanks for this! Never heard this before but will be trying it very soon!  I do a lot of miles on my 2008 KLR650 and it’s due another set of sprockets and chain this winter. Always surprised they don’t last any longer than they do. I keep them cleaned and lubricatored (most of the time).
Maybe this should be moved to a fresh post so more read it??
John,the strong power pulses of Big Single cylinder engine bikes:Thumpers  :) are a bit rough on sprockets And chains;I'm sure chain and sprockets last longer on multi-cylinder engine bikes.
I hadn't considered what Mark said in his post before:about modern rear sprockets being manufactured "molded"..
I have some NOS rear sprockets from 30 years ago and I see there is a difference between the look of a sprocket being 'machined' compared to the new "molded" look of the rear sprocket teeth of replacements.
I have ordered quite a few rear sprockets from Sprocket Specialists for a few decades and I'm familiar with the look of machined teeth.
I haven't seen those sprockets: are they machined?
Offline BenelliSEI
  • 1969 cb750
Re: Rear sprocket
« Reply #28 on: January 28, 2023, 03:12:23 PM »
Are you asking about “Uber’s”? Spellcheck error! I’ve corrected. Oops!
Offline grcamna2
Re: Rear sprocket
« Reply #29 on: January 28, 2023, 03:55:13 PM »
Yes, Sprocket Specialists makes their own sprockets from aircraft aluminum to any tooth range you want and they cut/machine their own sprocket teeth;they used to be out in Oroville,Ca.,began there in 1950? but they moved to Utah because they're under new management I think.    sprocketspecialists.com  They have great quality sprockets
« Last Edit: January 28, 2023, 03:57:09 PM by grcamna2 »
75' CB400F/'bunch o' parts'
