Author Topic: Is this aftermarket performance! Cb550 Manifold cone (pics)  (Read 1821 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: March 10, 2007, 03:17:03 PM »
OK, so I bought a 72 Cb500K with all kinds of aftermarket parts! I'm junking the frame and pulling all the parts off it. it's really ugly and the motor is frozen.
So, I get to removing the manifolds and I find these things! The bike came with a Kerker exhaust and velocity stacks.. I'm thinking it may have a performance cam in it. If you have an old Honda Clymers manual, it has all the performance parts listed in the back of the book! S&W shocks, exhaust, rearsets, dual disc, race covers, aftermarket coils, oil cooler, finned tappets and gauges everywhere! Please look at the pics I added!
Los Angeles Mods vs. Rockers, add yourself on!
http://www.myspace.com/bigwheellittlewheel
www.bigwheellittlewheel.com
Can fill me in on this:
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
  • 1976 CB550 K
Re: Is this aftermarket performance! Cb550 Manifold cone (pics)
« Reply #1 on: March 10, 2007, 03:23:07 PM »
Is this the aftermarket turbine fan accessory?  Do you think the velocity stacks let too much air in? And this was someones solution to lower the volume of air?
Was this a aftermarket product?
Nomad
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: March 10, 2007, 03:28:11 PM »
Those are those retarded 'tornado' gimmick engine performance reducers.
ZOMG, get teh 400MPGallunz, + trippul ur horsepowah!
Junk, remove em.
No.
Offline Bodi
« Reply #3 on: March 10, 2007, 06:40:15 PM »
The scientific principle is to create a vortex - spinning air - which creates a pressure gradient with the lowest pressure in the centre. Supposedly this puts higher pressure air where the valve opening is and lower pressure in the centre where the air/fuel mixture is reputedly banging into the valve. Whether this effect helps more than their restriction hurts is the big question.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: March 10, 2007, 06:40:37 PM »
Dude, they have been reviving that idea about every 10 years for over a hundred years. But those are the scariest looking set I've ever seen.LOL
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
« Reply #5 on: March 10, 2007, 08:20:18 PM »
They look like flow restrictors to me.  Maybe the turbulence helps low end torque and/or economy.  But, they just have to have degrading effects on top RPM air flow.  All those sharp angles and edges surely create trubulence and restrictive drag for airflow.
Offline MrFry
    • T-Fry.com <--Under Construction
« Reply #6 on: March 10, 2007, 11:41:13 PM »
the, idea of them is smart - swirling the air would help it go around turns, in say... an intake manifold in a car.
but the effect would be so little, you wouldn't even notice the difference in power or gas mileage.
putting them that clost to the intake valve wouldn't seem to help much - especially that big. Looks like a flow restriction to me (you would have to wonder why the manufacturer wouldn't do this if it were so great).
my favorite was when i pulled one out of the intake of a Turbocharged car...
lets see.... swirl the air, hit a turbine, no more swirl
