Author Topic: These fork uppers work on my cb500?  (Read 697 times)
Offline 78whiteorbs
« on: January 30, 2023, 04:05:36 PM »
Ok so have a 72 cb500 that's really nice but ape hangers and like 4 + fork uppers.
On a FB group guy has these pictured and told me these uppers from a cb450/cb350 with work with my stock lowers . He said they are "damping rod forks"
Will these fork with my stock cb500 fork lowers?
Offline 78whiteorbs
Re: These fork uppers work on my cb500?
« Reply #1 on: January 30, 2023, 04:09:52 PM »
My 72 cb500. After I fix the forks and bars it's on....oh and the longest kickstand ever !
Offline 78whiteorbs
« Reply #2 on: January 30, 2023, 04:15:53 PM »
Here's the lowers the stanchions pictured came from.
« Reply #3 on: January 30, 2023, 05:01:00 PM »
Yes they will fit, first 450 twin disc had 500 tubes with 750 lowers. The sliders you picture are 500 ones
Offline 78whiteorbs
« Reply #4 on: January 30, 2023, 07:22:26 PM »
So I am understanding this clearly, I CAN use the first stanchions pictured in my otherwise stock cb500 lower forklegs to de-chopperfy the front end ?
Thanks that's useful knowledge.
Offline pekingduck
« Reply #5 on: January 30, 2023, 10:38:55 PM »
Just to be sure, the CB/CL350s were 33mm fork tubes. The early CB450 Disc models, K3-K4, used CB750 style fork internals, no damper rods.  The CB450K5-K6-K7 used the damper rod style 35mm forks, along with the CB500 lowers. And yes, you can.
Offline 78whiteorbs
« Reply #6 on: January 31, 2023, 04:34:32 AM »
Awesome thanks!
Offline Little_Phil
« Reply #7 on: February 01, 2023, 09:21:34 AM »
How do you know you have stock lowers? They may be off a later 550. Then you will have to buy the complete forks.
Online Don R
« Reply #8 on: February 01, 2023, 09:57:21 AM »
 Look on the back side of the castings, if there is a 341 cast in, it's the same lower as a 750 just with shorter chrome tubes. I just assembled a 550 lower with the 21 13/16" Emgo replacement tubes from ebay to lower a 750 drag bike.
« Reply #9 on: February 01, 2023, 05:23:58 PM »
550 had caliper fittings on both sliders, 500 only on one
