Author Topic: 81 CB650 - cylinders 2 and 3 cold exhaust and backfire  (Read 769 times)
Offline randomguy81
« on: February 03, 2023, 03:53:20 PM »
Hi all
Have an 81 cb650 with cold exhausts on 2 and 3
Bike backfires
I’ve ran a compression test and I’m seeing 120 on all 4
I’ve switched over coils and cables
I’ve switched over CDI’s
I have spark on all 4 plugs
I’ve checked / adjusted valve clearances
Would really appreciate any advice of my next step - this bike is mentally beating me at every step it seems.
« Last Edit: February 03, 2023, 03:59:15 PM by randomguy81 »
Re: 81 CB650 - cylinders 2 and 3 cold exhaust and backfire
« Reply #1 on: February 03, 2023, 04:09:07 PM »
Sometimes a bad spark plug will spark in free air grounded to the engine but won't fire under compression. Never hurts to throw another plug in to see if the plug is defective.
Long shot but it has been happening with increased frequency past few years...
Are the non firing cylinders plugs wet with fuel?
Offline scunny
  • don't call me expert
« Reply #2 on: February 03, 2023, 04:29:19 PM »
"Are the non firing cylinders plugs wet with fuel?"
+1
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline randomguy81
« Reply #4 on: February 03, 2023, 06:12:23 PM »
Read this thread: ;D
http://forums.sohc4.net/index.php/topic,191710.msg2232615.html#msg2232615
Thank you - the problem I have is I am using an m-unit …
I am dreading working this out  ;D
« Reply #5 on: February 03, 2023, 06:30:59 PM »
Your ignition timing issue has NOTHING to do with a M-unit.
Offline randomguy81
« Reply #6 on: February 03, 2023, 07:19:41 PM »
I figured my wiring of the m-unit was the issue
Will follow that post
« Reply #7 on: February 03, 2023, 10:01:25 PM »
Most likely it is not related to your m-unit if it is wired correctly.
Ignition or fuel delivery issues most likely.
If you are getting spark then it is issue of fuel getting to the intakes, easily determined by wet gas on plugs of non firing cylinders.
650 is known to have issues commonly with CDI units and if you swapped them with no change then sounds like they may be fine...
The CV carbs are very picky about being clean and stock airbox to function correctly throughout Rev range. Early 650 didn't use CV carbs.
Offline randomguy81
« Reply #8 on: February 03, 2023, 10:28:12 PM »
Have just put a set of Mikuni vm34’s on from Murray’s
Had same issue with old carbs
Bike came with no wiring harness so I found a 750 schematic with the m unit and went to work
Going to try and change the pulsar yellow cables around as I believe from reading the link that was posted they are for 2 and 3
Offline randomguy81
« Reply #9 on: February 04, 2023, 07:01:02 AM »
My wife refused to let me fire the bike up at 1am so I switched my yellow wires this morning and crossed my fingers - she’s running on all 4!!!
THANKYOU SCOTTLY!
