Author Topic: 1978 CB750F Kick Stand  (Read 5974 times)
Re: 1978 CB750F Kick Stand
« Reply #25 on: March 12, 2007, 06:44:25 AM »
I have a shiny chrome F stand on my CB750K2 and as far as I can see the F stand is shorter - It dosent quite hit the sidestand rubber on the 4-4 exhaust. Different size. Not sure about lean angle as its on the center stand awaiting a new rear tire....:-(
cheers
Andy
Offline Lumbee
    • My pics...
« Reply #26 on: March 12, 2007, 07:30:44 AM »
...I'm sure others my do this, but when I park mine in the gararge I have a 2X4 I sit the kickstand on so it doesn't lean as far...
"I'm not a welder, but I play one on HondaChopper.com"
« Reply #27 on: March 12, 2007, 08:09:38 AM »
Yeah thats exactly what I do!
Offline Hockers Choppers
  • go away winter!!!
« Reply #28 on: March 12, 2007, 02:59:38 PM »
I just put a set of shorter shocks on. I can't afford a 2x4! :-\ There're on ebay all the time for $80. The ride if way better than the stock shocks.
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Offline SD750F
    • My Business Site
« Reply #29 on: April 07, 2007, 08:01:11 AM »
UPDATE UPDATE...
Well I got my frame back from the sand blaster yesterday (two weeks late!) and found the problem. The side stand mounting bracket on the frame was damaged. The whole bottom side weld line was pulled away from the support tube. The PO had even placed body putty in the crack to "hide" the problem...
No big deal... A little welding before powder coat and all will be well.
I will take pictures so all can see the damage.
Scott
Offline SD750F
    • My Business Site
« Reply #30 on: April 07, 2007, 04:26:25 PM »
Picture!
Well here are the pictures of my freshly sand blasted frame and the obvious weld damage and boss bend. You add the extra 10° from this and now I know why the bike excessively leaned when on its side stand...
Scott
  • go away winter!!!
« Reply #31 on: April 07, 2007, 09:48:03 PM »
Trick play with the bondo'd cracked weld!! Some po's should be slapped around! Good luck with the build!
cb750 k1
