Author Topic: CB750K1 Strange Situation  (Read 1329 times)
Offline pjandrew99
« on: February 11, 2023, 07:11:12 AM »
Been working on another project but now ready to get back to my CB750 and get it going.
Last time I took it out it ran like a bat outta hell for about an hour. Came off a highway ramp and the engine seemed to smooth out with some reduced power.
Rode it home and the engine seemed less sewing machine like and more V12 jag like. Again it had less power. Pulled in my driveway. It stalled and couldn't start it back up. Did the 3000 mile tune up. Still wouldn't start so put it away for the winter.
Before that ride I had added baffles to exhaust and wrapped the pipes. I also reduced one tooth on the front sprocket. WOW!, huge torque but wondering if I overheated or put too much stress on my engine possibly causing an issue.
So, my thoughts are to go through the entire electrical system again for starters. Did it once sometime before the ride and all checked out. Has newer coils, plugs and wires. Also, has Ricks combo regulator, rectifier. Battery is new.
The change in the engine smoothness may be a hint for one of the more experienced members to start me off in the right direction.  Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Old Scrambler
Re: CB750K1 Strange Situation
« Reply #1 on: February 11, 2023, 07:18:14 AM »
Assume you checked the plugs and points-gap.............but did you check the petcock and carbs for dirt?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: February 11, 2023, 07:29:23 AM »
I does sound like the plugs were  getting increasingly fouled.  Suspect the added baffles made the cylinders run a lot richer.  Pull the plugs and have a look.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: February 11, 2023, 08:06:25 AM »
Also check condensers
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline pjandrew99
« Reply #4 on: February 11, 2023, 08:24:18 AM »
Plugs and points were good. Thought I checked the petcock but I'll check it again to confirm. Carbs were on the list based on the responses I got. Thanks!
Was wondering about the need to change the jets. Right now I have 115/38 and the needles one notch leaner. That was done before the baffles when the bike previously ran rich. Would you change the jets or needle position based on adding the baffles? Thanks!
Condensors are newer. Is there a way to check them? Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Kevin D
  • SE Michigan
« Reply #5 on: February 11, 2023, 09:10:47 AM »
There have been many of the the 3 bladed logo condensers fail.
A fat blue spark at the points can be a sign of a bad condenser.
It’s harder to pay for the more expensive ($28?)condensers when you can get them for $8?, but worth it when your CB is running like crap.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline pjandrew99
« Reply #6 on: February 11, 2023, 09:16:43 AM »
Thanks! I've been meaning to crank it in the dark to see any errant sparks. I'll be sure to look down at the points.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #7 on: February 13, 2023, 09:13:20 AM »
Maybe a plugged gas cap vent?
Offline pjandrew99
« Reply #8 on: February 14, 2023, 01:58:49 AM »
Thanks! Will check it out.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #9 on: February 14, 2023, 02:28:40 AM »
jag v12 like?i would imagine that to be smoother than a rolls royce?
« Reply #10 on: February 14, 2023, 07:45:40 AM »
I would look at the spark plug tips for indications of mixture conditions when running.  Do you understand what metering circuit does what based on slide position?
« Reply #11 on: February 14, 2023, 08:37:29 AM »
jag v12 like?
A Jag V12 is as smooth as silk!
« Reply #12 on: February 14, 2023, 10:28:33 AM »
Deja vu?? Did you ever try removing the baffles and fiberglass packing?
http://forums.sohc4.net/index.php/topic,190366.msg2214129.html#msg2214129
« Last Edit: February 14, 2023, 10:39:42 AM by scottly »
« Reply #13 on: February 14, 2023, 10:31:57 AM »
Did you get rid of the #$%*ty ignition parts yet?
http://forums.sohc4.net/index.php/topic,190432.msg2215179.html#msg2215179
Offline pjandrew99
« Reply #14 on: February 15, 2023, 01:28:08 AM »
I did. Removed the slip on's and tried to start it. It didn't start and that's where I left it till now.
Yes, points were upgraded. Honestly don't remember what condensors I put in. Believe they are TEC.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline pjandrew99
« Reply #15 on: February 15, 2023, 01:57:57 AM »
Its' early. Had to think about it. Replaced the entire assembly plate with Honda assembly plate.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
