Author Topic: Painting side covers -- best practice(s)  (Read 978 times)
Offline carnivorous chicken
« on: February 11, 2023, 01:19:30 PM »
Will be repainting 350F side covers and I've looked but haven't found info here on best practice. Can't remove the paint with a stripper. Could sand -- but to bare plastic? Or just to smooth? The side covers I have a FMR, but will be repainting CBO. They're down to silver undercoat in some places.
For repainting, I saw somewhere here someone recommended an adhesive before applying paint, to make sure it won't crack with any flexing. But 350F covers mount differently, sli[ping over the tabs at the top and with a half-twist of the mounting pin at the bottom -- so not really any flex?
Re: Painting side covers -- best practice(s)
« Reply #1 on: February 11, 2023, 03:31:10 PM »
 I would sand to your hearts content with some of the black 400 wet/dry sand paper and water to prep them for primer and paint.
« Last Edit: February 13, 2023, 05:19:29 AM by ekpent »
Offline Kenzo1979
« Reply #2 on: February 11, 2023, 06:09:01 PM »
Yes, use adhesion promoter before primer and paint.  It’s a must for plastic IMO.  Stuff I’ve used is called bulldog, comes in a rattle can.  Posted a pic of it on another thread at some point.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Mark K
« Reply #3 on: February 12, 2023, 07:49:52 AM »
I sanded my '73 750 side covers down to the bare plastic, as they needed crack repairs in a few places. After repair, primed several coats, then several coats of paint, followed by clear coat (all rattle can). I did not know about using adhesion promoter, but I do now. Thanks Kenzo!
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Online Don R
« Reply #4 on: February 12, 2023, 08:51:20 AM »
  Sand to smooth, then adhesion promoter then sandable primer, then primer sealer, then color paint.
Offline Ujeni
« Reply #5 on: February 13, 2023, 06:46:13 PM »
That's exactly right. No need to sand all the way to plastic, just to smooth. Painting on top of existing paint is perfectly fine assuming you have good adhesion. If you sand to the plastic in any spot, use the plastic adhesion promoter before primer.
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
