Author Topic: Turn signals/headlight issue  (Read 656 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: February 11, 2023, 01:45:26 PM »
Sooooo I have been plagued with this gremlin since I acquired this bike in October.
1975 cb550k1
Signals wouldn’t turn on and headlight would work every once in a while.
I rearranged all the wiring in the birds nest to match the diagrams.
Finally I have the turn signals working.
But … when I turn the switch for the headlights in without headlight attached. The signal flasher makes a sound but front headlights flash opposite.
Once I connect the headlight the flasher doesn’t work anymore and the headlight coil glows but doesn’t turn on.
Any insight?
Please help me. Lol
JD
1975 CB550K1
Online newday777
Re: Turn signals/headlight issue
« Reply #1 on: February 11, 2023, 07:38:15 PM »
Something isn't wired correctly in the bucket.
Stu
My current rides
Prior bikes....
« Reply #2 on: February 11, 2023, 09:10:11 PM »
The nuts holding the headlight mount bolts are supposed to have terminals that connect to the green wires in the harness.  Do you have those connected?
Offline JDrider
« Reply #3 on: February 12, 2023, 04:30:48 AM »
Yes, there are grounds on both nuts and they are connected to a main ground.
JD
1975 CB550K1
« Reply #4 on: February 12, 2023, 02:39:59 PM »
  It sounds like the running light wires are crossed with the turn signal wires, a shorted out light bulb can act weird also. These is a light blue, black with a blue band, black with an orange band, and a darker blue in the harness, be sure the blues aren't crossed.
Offline JDrider
« Reply #5 on: February 13, 2023, 01:59:28 PM »
After checking all the wiring colors and connections.
Everything looks correct.
I have noticed the signal grounds prefer one of the ground connection to another ground connection.
I didn’t think it should matter which ground connections things are grounded to. Odd.
I also noticed a 9 volts reading on one of the green ground junctions
JD
1975 CB550K1
« Reply #6 on: February 13, 2023, 02:06:08 PM »
Then something is connected wrong
Offline JDrider
« Reply #7 on: February 14, 2023, 04:47:37 PM »
The ground wire that is acting up is the one that goes from the rear signals to the front.
When checking for continuity from the rear to front, there is none.
So, I’m to assume the wire is broken somewhere in the main wire harness?
What would cause it to have 9 volts?
JD
1975 CB550K1
« Reply #8 on: February 14, 2023, 08:51:30 PM »
9 volts compared to what voltage source?  Where are your measuring points and ground reference?
Offline JDrider
« Reply #9 on: February 15, 2023, 03:57:30 AM »
I'm getting 9 volts on my ground wire. That same main ground that goes from rear signals to front is also not showing continuity.
JD
1975 CB550K1
« Reply #10 on: February 15, 2023, 07:26:01 AM »
9 volts on a single wire is unmeasurable without a return reference. Your meter has two probes and they must both be employed to get any reading on the display.
You also need to state how much voltage is available to distribute on your machine.  Is your 12v battery run down to 9v?
No one can troubleshoot/analyze  a system without collecting a list of “knowns” about the circuit.  The less you know, the harder to understand what is happening in the circuit and explain meter readings.
That said, do I assume correctly you have located a broken green wire?  If so, a physical exam of that circuit path is in order.  The rear signal mounts are rubber isolated. Did you check the wire jumper to make a path from bulb base to green ?
Offline JDrider
« Reply #11 on: February 15, 2023, 07:35:24 AM »
I measured voltage using red probe on green ground coming into headlight bucket from main wiring and black probe on the ground wire nut inside the headlight bucket.
I have a fully charged battery.
My point was that I was seeing voltage on a ground when I did that.
Also, when probing the green ground that is attached to rear turn signal junction all the way to the green ground junction in headlight bucket in question, I wasn't getting continuity.
I was getting continuity when testing all other green wires the same way in bucket.
JD
1975 CB550K1
« Reply #12 on: February 15, 2023, 08:58:45 AM »
All the green common ground wires on the bike should reference the battery neg terminal.  All should read zero volts, when using the red probe on any green connection  and keeping the black probe on battery neg (or as near to it as convenient).
Offline JDrider
« Reply #13 on: February 15, 2023, 09:02:56 AM »
Yes, I know this. I posted because it isn't. I'm trying to figure out what is going on.
JD
1975 CB550K1
Offline JDrider
« Reply #14 on: February 16, 2023, 05:40:30 AM »
Found that the one ground wire was broken, Im sure others are too.
see in new post
http://forums.sohc4.net/index.php/topic,191951.0.html
JD
1975 CB550K1
