Author Topic: Center stand repair CB500k3  (Read 690 times)
Offline Teddyhoeg1982
« on: February 13, 2023, 10:09:26 AM »
Previous owner really butchered the frame brackets for the center stand. Anyone with experience repairing this? I can do decent TIG welding but was wondering how to fabricate the missing pieces.
Online newday777
Re: Center stand repair CB500k3
« Reply #1 on: February 13, 2023, 11:08:44 AM »
Probably cheaper and easier to buy a section of a frame and cut and weld that in yours or whole frame.
Stu
My current rides
Prior bikes....
« Reply #2 on: February 13, 2023, 12:25:00 PM »
Unfortunately frames like these would cost 2-300$ here in Denmark, so I was looking to repair it by constructing a new piece.
« Reply #3 on: February 13, 2023, 01:05:13 PM »
weld a big heavy washer over the hole,you dont really need the split clamp part for it to operate,i only slip my centre stand on for wheel or chain service.
« Reply #4 on: February 13, 2023, 01:14:50 PM »
  Dave is correct any metal shape with a hole in it can work, if you want it factory appearing, you need a cut off part.
  I made a replacement tube and heated and re-shaped the brackets after a PO ruined the parts.  It now has a cotter pin on each end. I have also narrowed a center stand so it may be used with a 4-2 header.
« Last Edit: February 13, 2023, 01:21:09 PM by Don R »
« Reply #5 on: February 13, 2023, 01:36:38 PM »
i had to butcher mine to clear a 4/1 pipe,added big feet while i was at it for extra stability
Offline pekingduck
« Reply #6 on: February 13, 2023, 01:37:40 PM »
Previous 2 have good advice.  I would put a straight pivot shaft in the holes and hose-clamp it to the parallel frame tube to hold in place.  Then try to heat and re-form the left one to shape. Then as Dave mentioned above, put a thick, snug fitting washer on the outside of the right bracket and weld in place, and brace it.  The right side of the pivot shaft can be held in with a cotter pin.
Or you can have this piece for the price of postage. I'm in Calif. 91803 and it weighs 1lb.
« Last Edit: February 13, 2023, 02:01:21 PM by pekingduck »
Offline pekingduck
« Reply #7 on: February 13, 2023, 02:16:17 PM »
Judging by the tubular passenger peg support, yours appears to be a SuperSport model.  Same pivot shaft though.
« Reply #8 on: February 13, 2023, 02:39:45 PM »
In Denmark they made a CB500K3 that resemble a super sport styling, but it is a CB500k
Offline Shtonecb500
    • Youtube profile
« Reply #9 on: February 13, 2023, 02:48:35 PM »
Man, I would not be splicing my frame just to repair/replace that part....if you are welding in a spliced frame then you should be able to handle making something that functions the same as stock. Get some flat stock and weld in a spacer large enough for a bolt to drop through like the original set up.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline pekingduck
« Reply #10 on: February 13, 2023, 03:38:22 PM »
I certainly agree about splicing a section in, and that wasn't my intent.  The stamped pieces can be cut from the tube and welded on, but I wasn't going to do that.  I just cut up an old frame that was headed to scrap.
« Reply #11 on: February 14, 2023, 08:34:46 AM »
So I just ended up fabricating something, and it turned out to work really well.
Online newday777
« Reply #12 on: February 14, 2023, 09:54:21 AM »
Nice job!
Stu
My current rides
Prior bikes....
« Reply #13 on: February 14, 2023, 02:51:37 PM »
well done.
Offline Shtonecb500
    • Youtube profile
« Reply #14 on: February 14, 2023, 07:04:16 PM »
nice work.
« Reply #15 on: February 15, 2023, 09:26:35 AM »
Nice, and good fab skills. Now to clean that area up...
Offline BenelliSEI
  • 1969 cb750
« Reply #16 on: February 15, 2023, 10:21:11 AM »
Very nice job!!
« Reply #17 on: February 15, 2023, 03:26:53 PM »
Just sent the whole frame, swingarm and stand for sandblasting and powdercoat. Should be ready in a weeks time.
« Reply #18 on: February 17, 2023, 06:54:50 AM »
Perfect...you will love the powdercoat, I've done a couple of mine.
