Author Topic: Do these dowel pins sit proud of cylinder, or flush?  (Read 499 times)
Offline denward17
« on: February 17, 2023, 07:11:03 AM »
I had my K8 cylinder milled (.003" off).
Looking at the 8-12mm dowel pins and they are sitting proud of the cylinder now.  I didn't check when I tore it apart if they were flush.
Are they supposed to be flush with the cylinder?
Offline denward17
Re: Do these dowel pins sit proud of cylinder, or flush?
« Reply #1 on: February 17, 2023, 09:35:26 AM »
I went ahead and took off ~.7mm off of each one so they would sit flush, makes sense to me.
Offline Little_Phil
« Reply #2 on: February 17, 2023, 09:57:29 AM »
.7 or 0.07mm?
Offline denward17
« Reply #3 on: February 17, 2023, 10:34:30 AM »
.7 or 0.07mm?
It was around .003" which is .07mm, thanks for keeping me straight.. :)
Online grcamna2
« Reply #4 on: February 17, 2023, 11:01:12 AM »
When you get them all done,blow-out all the holes and put some oil on them and do a 'test fit' with your cylinder head;Mike may have had it milled a little also.
Offline denward17
« Reply #5 on: February 17, 2023, 11:43:08 AM »
Yes, Mike milled the head .003" as well, but that only affects the 2 bigger knock pins at the front corners and they have room to spare, but will re-check to make sure.
