Author Topic: 1978 CB550K - Rear light relocation issue  (Read 615 times)
Offline MrBaklava
« on: February 26, 2023, 06:52:02 AM »
Hey folks,
I recently removed the rear light + number plate platform from the rear of my CB, and mounted the indicators directly to the rear fender. I have retained the original wiring.
Now, my rear indicators are no longer working at all. I think from looking at the wiring diagram, that the rear light must have grounded the indicators - is this correct?
If someone could please advise me how I can get the lights operating again, that would be great.
Thanks in advance!
Offline BenelliSEI
  • 1969 cb750
Re: 1978 CB550K - Rear light relocation issue
« Reply #1 on: February 26, 2023, 06:58:49 AM »
From memory, my ‘78 550K has a separate grond lead that went under the mounting nut for the stem that mounted them to the original grab bar? It used a large ring end, crimp d to the ground wire. Try bolting that under the mounting lug, under the fender?
To test first, clamp a jumper cable to your negative (-) lead on the battery and the lamp housing. If the turn signal starts working, you have no ground.
If you are using after market stems, and they are rubber, run the ground wire into the lamp housing and using a small ring end, attach it to one of the tiny screws that secure the lamp socket to the reflector.
« Last Edit: February 26, 2023, 10:14:21 AM by BenelliSEI »
« Reply #2 on: February 26, 2023, 07:55:32 AM »
How many wires did you connect to each of the signals?
What wire colors did you attach to at the wire harness?
Offline MrBaklava
« Reply #3 on: March 02, 2023, 11:52:06 AM »
Thanks a lot folks. I added a ground and the lights are now operating perfectly.
