Author Topic: Head Gasket Selection Help?  (Read 1522 times)
Offline BenelliSEI
  • 1969 cb750
Re: Head Gasket Selection Help?
« Reply #25 on: February 28, 2023, 05:45:42 PM »
Gentlemen….. Thsnks for all the great advice! Much appreciated. John D.
« Reply #26 on: February 28, 2023, 09:36:46 PM »
I test first if nuts will move when continue with same tourqe when I want to know how much gasket has compressed.
Nut by nut from inner to outer.
Next is to loosen 1/2 turn followed by tighten again.
The thin M6 as last ones. 4 under rubber coins + 2 on each side of cam tunnel.
The earliest have only 1.
If the nuts sat loose, I'll redo the day after again. No hurry when working at home for myself ;)
Thanks Per. Will give this a try. J.
Loosen 1/4 turn is enough just before retighten the last again
Since I have wrenches in Nm, I tighten, 5, 10, 15, 20, 25 ... (MLS need 29Nm. It will collapse a little just before when it feels easier)
I have 2 wrenches.  German made Hazet.
1/4" 2.5-25Nm (usually max 15Nm with it)
1/2" 10-60Nm
All M6 max 9 Nm. I tightened 10Nm before.
But why tighten just above max for grade 8.8 bolts in steel when aluminium is not that durable?
Too many thread inserts used.
https://www.unitconverters.net/energy/ft-lb-to-nm.htm
« Last Edit: February 28, 2023, 09:53:42 PM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #27 on: March 01, 2023, 01:22:43 PM »
Curious why you all pull the head nuts so tight? All my early (and later) copies of the Honda workshop manuals say 15.9 ft.lbs.
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #28 on: March 01, 2023, 07:48:14 PM »
I have a Cruzin Image 836 head gasket and Mark said they should be ok.  It's 1.55mm thick.  When I put it on my shaved jugs, I get a dimension of 2.66 so I would need an o ring larger than 2.66.  Does that make sense.  Can I use two o rings to fill it in?  DON'T WANT A LEAKER.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
« Reply #29 on: March 01, 2023, 09:22:16 PM »
 Which dimension is 2.66?
« Reply #30 on: March 01, 2023, 10:04:11 PM »
I think he’s talking about the fire ring Don? 67.5mm. ;D
« Reply #31 on: March 02, 2023, 01:50:32 AM »
Oil feed o-rings for thicker gaskets, 1-1.2mm thick.  10.78x 2.62mm
(Stock 11x2.5mm)
I'll measure mine CI 836 gaskets.
Rather sure they are 1.2mm thick measured on the fiber area, not metal rings around bores.
« Last Edit: March 02, 2023, 09:27:12 AM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: March 02, 2023, 05:50:01 AM »
Ed.... is the 2.66= 2.660”? Is that the I.D. of the bore (piston holes)? Why do you need “0”rings that diameter? As PeWe suggested, measure your head gasket thickness at the fibre edge.
« Last Edit: March 02, 2023, 01:22:19 PM by BenelliSEI »
« Reply #33 on: March 02, 2023, 09:01:56 AM »
I measured mine. I'm rather sure it is a CruzinImage gasket
1.25 mm thick. It will compress for sure.
Tighten nuts by 20 ft lbs. Not less when using 836 and higher compression.
Retighten after 24 hours or longer.
O-ring comoression calculation:
Gasket + o-ring groove max 2.2mm.
O-ring thickness 2.62mm makes 0.42/2.2 mm compression of 0.1909-->19.1% wich is just under minimum recommended compression.
20-30% as I found at an o-ring resellers specification.
O-rings can not be too thick. They can collapse inwards.
Lets say that gasket compress 0.1 mm further, total 0.15mm. 1.1mm thick, o-ring groove in cylinder 1mm. It can be 0.9 too or less if milled without adjusting the o-ring grooves.
# Total depth 2.1mm,
#  o-ring 2.62mm
Compression:
# o-ring- total depth= 0.52.
0.52/2.1=0.2476-->24.7%
This will be fine.
If o-ring groove is 0.9mm
Gasket compress to 1.1mm
Total 2.0mm
Compression  0.62/2.0=0.31 -->31% which is at max.
In last case with stock o-ring 2.5mm thick
Compression 0.5/2.0=0.25 -->25%
 O-rings Hondaman has recommended on several forum threads. 10.78x2.62mm. This is a std size possible to order from several sellers.
I have ordered viton from UK.
Gasket below 1.25mm thick, photo might not show exact due to  where camera lens is located, parallax error.
« Last Edit: March 02, 2023, 11:24:53 AM by PeWe »
