Author Topic: Has anyone used the Alpha Moto carb sync gauge tool?  (Read 4439 times)
Re: Has anyone used the Alpha Moto carb sync gauge tool?
« Reply #25 on: March 14, 2023, 01:38:18 PM »
And just to be sure put a nice fan on the motor during sync so you don't overheat.
+3
Very important. A quick sync might take longer time than expected.
I use a table fan placed on the floor.
I let it continue to blow another 5-10 minutes after sync is done and engine off.
Offline Deltarider
« Reply #26 on: March 15, 2023, 03:57:37 AM »
[...] but also (they claim) you can identify issues with valves  [..]
Any old style manometer does this, if you know how to 'read' it.
No doubt I'm fan of old-school tools (as already mentioned RPM meter, voltmeter etc), but sometime modern tool is good too  ;)
Same here. When testing dynamically, I prefer analogue voltmeter, dwellmeter, tacho and EGA over digital anytime.
CB500K2-ED Excel black
Offline Deltarider
« Reply #27 on: March 15, 2023, 03:59:56 AM »
[...] but works even better when the tubes are restricted with some old pilot jets to buffer the readings. [...]
Did some experimenting with the plastic containers Yuasa used to send the acid in (not anymore, at least not in Europe). They proved the perfect dampeners in between the manifold exit and the manometer. The containers shrunk in the process but gave a very stable reading. And... Yuasa even supplied a tube!
Offline Deltarider
« Reply #28 on: March 15, 2023, 01:09:45 PM »
Drugsgsm, that center tube on yours intrigues me. Can you shed a light on that? BTW, what's the blue fluid? Startron? Blue Curaçao?
Offline BenelliSEI
  • 1969 cb750
« Reply #29 on: May 03, 2023, 05:39:25 PM »
I suspect that is the “fill line”, but would like to hear the answer???
Offline Seymore82
« Reply #30 on: October 07, 2024, 11:10:49 AM »
I like my Digi Sync digital carb sync gauge. Will never go back to the gauges after trying this tool. Don't have to calibrate or mess with restrictors. This tool just does all that work for you digitally!
Check it out: www.TheDigiSync.com
Offline BenelliSEI
  • 1969 cb750
« Reply #31 on: October 07, 2024, 05:31:45 PM »
Just read their ads and watched the video. Definitely on my Xmas Wish List.
Offline Rayzerman
« Reply #32 on: October 08, 2024, 06:22:45 AM »
I can't recommend the DigiSync.... could never get it to work.  They initially responded to my queries, and it was clear to me the unit was defective.  Refused to talk to me after that.  I used a Morgan Carbtune for years, until I found a used Techmate.  They are very expensive but just plain awesome to use.
https://tecmate.com/vacuummate-allweather/
Offline BenelliSEI
  • 1969 cb750
« Reply #33 on: October 08, 2024, 06:42:13 AM »
Ouch….. not good!
Offline carnivorous chicken
« Reply #34 on: October 08, 2024, 06:53:38 AM »
Sorry, but this screams shill. Two posts, both on old threads about carb syncing.
Offline Deltarider
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #36 on: October 08, 2024, 07:43:08 AM »
4 analog gauges with some dampers on the hoses
Simple, effective, not too expensive.
We have to remember that this is all they had back then and they got great results with it. I like constant improvement and I usually go for constant improvement but a hammer is still useful.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Deltarider
« Reply #37 on: October 08, 2024, 07:58:09 AM »
Well said! We don't need no stinking gadgets.
