Author Topic: Cb750 Cam Covers Date Stamped  (Read 1884 times)
Offline BenelliSEI
  • 1969 cb750
Re: Cb750 Cam Covers Date Stamped
« Reply #25 on: March 06, 2023, 05:48:35 AM »
44=1969, they increase year to year at the same rate so 45=1970, 46=1971 etc.
  Other tells on the early rocker covers is the waffle or X pattern seen here in the casting depressions, the case vent has no baffle, and the speedometer drive screw boss does not protrude past the rest of the casting. (feels flat)
Don..... looked at the tach drive this am and you ar spot on. Interestingly, both the K3 and K4 are different too!
Offline BenelliSEI
  • 1969 cb750
« Reply #26 on: March 06, 2023, 09:47:56 AM »
Here’s what Don is taking about. Old one (short tach screw boss) on top.
Offline BenelliSEI
  • 1969 cb750
« Reply #27 on: March 06, 2023, 09:49:25 AM »
Date stamp on the K3, also as Don described in his note. The lock tab is missing. I modified it to fit the S/C cover.
« Reply #28 on: March 06, 2023, 01:03:01 PM »
44 4 8 is April 8, 1969
1969-44=1925.  What happened in Japan in 1925?!
Offline robvangulik
  • Honda Fourever
« Reply #29 on: March 06, 2023, 01:57:23 PM »
See reply #7
Offline 69cb750
« Reply #30 on: March 07, 2023, 04:04:42 AM »
48 12 11 is December 11, 1973
Showa date system begins, here are five date systems - https://www.meijishowa.com/info/72/japanese-dates
