Author Topic: R4 vs. R5 Cam  (Read 1187 times)
Offline Fasted
  • 99% done now
R4 vs. R5 Cam
« on: March 11, 2007, 07:42:50 AM »
Can someone tell me the difference between an R4 and a R 5 cam on the CB 750?
ED
1969 Sandcast rebuild!
Re: R4 vs. R5 Cam
« Reply #1 on: March 11, 2007, 08:02:51 AM »
Nothing at all its just a casting/machining mark
Offline rbirkhan
Re: R4 vs. R5 Cam
« Reply #2 on: March 11, 2007, 10:07:10 AM »
Get those heads/pistons/cylinders/valves cleaned up I will get you the hone wednesday. I expect you will have all this done asap. Order your cam wheels as you cant reassemble it without them.  ::) getting those pistons back in will be a pita.  I can loan you the porting kit it makes cleaning the ports on the heads a 5 minute deal with the die grinder and the fluff wheels.  I also have some long brushes you can use to clean out the fins before you spray.
