Author Topic: Replacing all JIS screws with SS barrel bolts…anti-seize?  (Read 1003 times)
Offline JohnnyL
« on: March 13, 2023, 05:19:20 AM »
Opinion and suggestions needed…
Like the subject line states…I’m replacing all JIS screw with SS barrel head bolts. Do I use anti-seize or red/blue lock tire?
1978 CB 750K
Thanks
Offline denward17
Re: Replacing all JIS screws with SS barrel bolts…anti-seize?
« Reply #1 on: March 13, 2023, 05:28:03 AM »
Assume you are referring to replacing all side cover/valve cover JIS screws?
I can't comment on the SS properties as it relates to interaction with aluminum with anti-seize, but there is probably a special type that is needed, probably wouldn't hurt as long as you got the proper type.
I don't think you would want any kind of Loctite on any of these.
« Reply #2 on: March 13, 2023, 05:28:28 AM »
If you use loctite on stainless in alloy you will probably need dynamite to ever get them out again
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: March 13, 2023, 05:28:40 AM »
I just use anti seize and be careful not to put too much “grunt” on them. Use a 1/4 drive, small ratchet and go gently. Also ensure each screw engages in the case by 1.5 X the diameter of the thread. Too little and you will strip the case threads.
Honda used Philips head screws so it was impossible to over torque....
« Reply #4 on: March 13, 2023, 05:29:46 AM »
No, they used jis screws cos they were cheaper! Later bikes had 8mm hex heads
« Reply #5 on: March 13, 2023, 05:44:05 AM »
The instructions I got with a nice 750 kit said to use anti-seize. Wish I could remember the suggested formula. Got a container hiding in the shop.
Online PeWe
« Reply #6 on: March 13, 2023, 06:16:07 AM »
I use a torque wrench for all covers. Too many thread repairs.
https://www.unitconverters.net/energy/nm-to-ft-lb.htm
I usually tightened with 10Nm (7.37 ft lb). I have reduced that to max 7.5Nm (5.53 ft lb) with new gasket. Or 5Nm with old.
Lately valve cover to 5Nm (3.68 ft lb) and retighten the day after if gasket is new. This is what I can tighten with a screwdriver.
Valve cover threads have got many inserts in a few heads.
Tighten harder to avoid leak is not working.
I changed to allen heads for many years ago and too easy to tighten ;) ;D
Aluminium paste is a good anti seize and handle very high temparatures . I use it on sparkplug threads.
« Reply #7 on: March 13, 2023, 07:47:37 AM »
Barrel head?  Never heard them called that.  Socket head screws.....
And I also use a 1/4" ratchet to install.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: March 13, 2023, 07:47:49 AM »
+1 on torque wrench, it's way to easy to over torque
+1 on what PeWe said about keeping torque low, again, way to easy to pull the threads
+1 on anti-seize, a must with stainless in almost any usage, especially in these tiny 6mm threads
I battle corrosion here in paradise, stainless is a real help.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: March 13, 2023, 07:48:39 AM »
Yes, they are also called  socket head cap screws
1973 CB 750 K3
« Reply #10 on: March 13, 2023, 09:22:35 AM »
Would allen head bolt qualify also  :D
Online PeWe
« Reply #11 on: March 13, 2023, 09:23:58 AM »
+3 ;D
We call it "Insex" over here.
« Reply #12 on: March 13, 2023, 10:26:46 AM »
Technically, no!  Allen is a brand name.
"Hex keys are also known as Allen wrenches. In the early 1900s, the Connecticut-based Allen Manufacturing Company launched its own branded hex key, naming it the “Allen wrench.”
Offline Kelly E
  • Geriatric Hooligan
« Reply #13 on: March 13, 2023, 11:46:14 AM »
We always use anti-seize on all bolts when assembling the bikes. I have a WW II vintage Plumb 1/4" drive 6" long extension I use to tighten all 6mm fasteners. It works like a torque stick, you can only tighten so tight before it starts to twist the extension. I've never stripped the threads in aluminum since I started using it.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #14 on: March 13, 2023, 01:22:19 PM »
I collect old plumb tools. I've got a few pebble finish wrenches. Love them!!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline Kelly E
« Reply #15 on: March 13, 2023, 06:58:44 PM »
I have a few wrenches stamped war finish.
1983 Honda CB 1100F
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #16 on: March 13, 2023, 07:49:14 PM »
Neither have I...
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline C317414
« Reply #17 on: March 14, 2023, 05:00:02 AM »
1978 CB 750K
Thanks
I would use a non-metallic anti-seize compound or a non-metallic grease.  The majority of anti-seize compounds contain metals that are more noble than aluminum.  If moisture makes its way into the area from bike washing riding in the rain, etc, bare aluminum and stainless, or aluminum and stainless with a metallic grease or anti-seize may cause the aluminum to corrode.
Marine grease is non-metallic, and is often available in smaller tubes.
Offline JohnnyL
« Reply #18 on: March 15, 2023, 02:00:29 PM »
Yea those are the bolts..I’ve always called them barrel bolts LOL
Offline JohnnyL
« Reply #19 on: March 15, 2023, 02:06:08 PM »
Great info. Thanks you all so much.
Yea I’ve always called them Barrel heads. I guess the common name is Socket Cap Head.
I’m replacing EVERY JIS screw with these SS Bolts.
Again thanks for all the info, appreciate it.
John
Offline Trevor from Warragul
« Reply #20 on: March 15, 2023, 03:37:05 PM »
I've used this method for years. Makes disassembly a breeze!
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #21 on: March 16, 2023, 02:19:41 AM »
We call them inbus  :)
I think Inbus was a manufacturer in Germany.
