The SOHC/4 World Tour is in under way.
If the cables are disconnected and you actuate the carbs by hand, do they snap back?
Those look like new cables. Did you lube them?? And make sure your return mechanism is lubed as well. And make sure your slides don’t have excess friction. And in my experience most 70s bikes with original carbs don’t really SNAP back so much as leisurely kinda return.
Quote from: MauiK3 on March 14, 2023, 03:08:15 PMIf the cables are disconnected and you actuate the carbs by hand, do they snap back?Yes, and if they do, Check that your throttle cables move freely back-and-forth as you twist the throttle, silky smooth. Then check your cable routing, it can definitely jam you up.
+1 Carbs have to return with no cables..👍✅🎯Then make sure your not loading the cable and throttle tube..See overcross adjustment…🤔
