Author Topic: How the heck does the rear fuel tank rubber mount go on?  (Read 392 times)
Offline denward17
« on: March 20, 2023, 04:29:04 PM »
I purchased a new rubber rear tank mount a few months ago and just now installing.  For '78 CB750K.
I cannot find any reference to understand if the triangular tab goes to the front or rear.
Any ideas?  #13 in the pic.
Offline robvangulik
  • Honda Fourever
Re: How the heck does the rear fuel tank rubber mount go on?
« Reply #1 on: March 20, 2023, 04:47:58 PM »
The drawing shows clearly how it should be, put the rubber on from the front side, you use the tab to pull the rubber back to mount the tank!
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #2 on: March 20, 2023, 04:50:28 PM »
Yep. Trust the drawing.
Offline denward17
« Reply #3 on: March 20, 2023, 05:03:42 PM »
I tried multiple times and thought I was going to pull the tab off.  Will try again.....
Offline Johnie
« Reply #4 on: March 20, 2023, 05:48:00 PM »
It will feel like you're going to tear it. I pull the tab and put one side in at a time.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #5 on: March 20, 2023, 06:54:23 PM »
I have also recently received one for a 750K7 that was 'backward'. It had to be mounted with the triangular tab pointing forward. There were some 750F1 bikes like that, too, using the parts made after about 2006 or so.
Online newday777
« Reply #6 on: March 20, 2023, 07:23:42 PM »
Hint, just like on the side cover grommets, spray some silicone on it to help it slide on and off easier.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #7 on: March 20, 2023, 07:37:43 PM »
That's the only way it makes sense to go on to me, with the triangle facing forward.
