Author Topic: Dunstall fairing/ fiberglass bodywork  (Read 3347 times)
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« on: March 22, 2023, 07:06:35 AM »
I have always wanted one of these fairings. Checked shows and swaps. I am far too cheap to purchase a new set. Picked up a set of well made molds from a boatbuilder. Going to make some up. Any interest/ motivation or advise would be fanfreaking tastic!! Thanks guys!
These are the molds. I also got some seat pan molds for a triumph T140?
This is the goal. (On a cb750F though of course)
Re: Dunstall fairing/ fiberglass bodywork
« Reply #1 on: March 22, 2023, 07:14:51 AM »
Hey Franken!   I've always wanted one too, thats why I bought this K3 project bike and restored it. Appears to be a diff model though.
« Reply #2 on: March 22, 2023, 07:31:57 AM »
SteveO!! Yeah buddy. Looks like same model, just the bottoms aren’t on there. I have the molds for them on table in the pic.
« Reply #3 on: March 22, 2023, 07:40:39 AM »
Very cool...looking forward to seeing you produce them!
Online Alan F.
« Reply #4 on: March 22, 2023, 08:02:14 AM »
That's a great project! I could drop by with my Royal Enfield Interceptor if you'd like to check fit. I'll bet you'd sell a few for those bikes.
On a separate note, I was wondering if you'd be interested in making molds for CB160 side covers? I've got a set handy.
« Reply #5 on: March 22, 2023, 08:07:28 AM »
The Dunstall fairing is probably one of the most beautiful fairings made for CB750 ;)
The glass is easy to get?
I have a short fairing with rectangular headlight and rectangular inlet for oil cooler.
Said to use Dunstall glass.
From the old catalog from my local go fast parts and work shop.
« Last Edit: March 22, 2023, 10:46:13 AM by PeWe »
Offline newday777
« Reply #6 on: March 22, 2023, 08:50:34 AM »
They are very cool.   8)
Steve at Honda Restoration in NH, has a whole Dunstall kit on a 75 K5 he wants to sell as a package. He'll be back around the end of April if you want to get together with him.
Stu
My current rides
Prior bikes....
« Reply #7 on: March 22, 2023, 10:16:34 AM »
Roadtriiiiip
Online Alan F.
« Reply #8 on: March 22, 2023, 01:22:12 PM »
Don't use Google maps though...  ???
Offline Shtonecb500
    • Youtube profile
« Reply #9 on: March 25, 2023, 11:16:44 AM »
im gonna follow this cause I have a one piece body kit and the molds to remake it and dont know #$%* about fiberglass.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline newday777
« Reply #10 on: March 25, 2023, 11:28:47 AM »
Roadtriiiiip
Yup. Have you been to Steve's shop?
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #11 on: March 25, 2023, 11:31:25 AM »
Very true! My 1st time going there Google maps sent me out to the back trail that is an old tote road that isn't a road!
Stu
My current rides
Prior bikes....
Online Alan F.
« Reply #12 on: March 25, 2023, 12:05:15 PM »
I wound up making a morning ride out of those dirt roads. I enjoyed myself so much I've bought a set of Shinko 244s for my Enfield Interceptor this year.
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: April 08, 2023, 01:50:55 AM »
Alan....Next time check out Kenda K761’s. My son put them on 19”F and 18”R Lesters on our K3. Great in gravel and work really well on pavement too!
« Last Edit: April 08, 2023, 01:52:48 AM by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #14 on: April 08, 2023, 08:00:02 AM »
Do they make noise?
They look somewhat like the stock tires that were on my 2009 Ruckus (sold it) and they had a nice hum.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #15 on: April 08, 2023, 11:25:54 AM »
3 coats paste wax then PVA spray
« Reply #16 on: April 08, 2023, 11:26:22 AM »
« Reply #17 on: April 08, 2023, 11:27:55 AM »
Using some mix of stuff on hand. Ideally I think a couple nice big pieces of unstarched woven would be perfect.
Thinned out the epoxy with denatured alcohol for wetting
« Reply #18 on: April 08, 2023, 11:28:57 AM »
First trial run. Going at it without gel coat for now. Trying to produce something without needing to buy any extra supplies.
Offline WideAWAKE
« Reply #19 on: April 08, 2023, 03:33:32 PM »
Dont take this the wrong way but your layups don’t not look all that great, lots of air bubbles and unsaturated glass.
Get yourself a bubble buster (layup roller) and some (fresh) poly resin. Poly resin will flow though and saturate the cloth much easier than epoxy which likes to be “pushed/pulled) through.
Without a vacuum bag you probably aren’t gonna hand layup any big/complex curves with woven glass.
In your case, chopmatt is your friend.
If you want it to look super clean go of it, you can run your mold with gelcoat let it gel, then lay down your chopmatt with poly and roll it real good. You will have a clean layer of solid gelcoat without hairs in it that requires little to no sanding.
« Reply #20 on: April 08, 2023, 04:01:29 PM »
Ha. Yeah. Be honest. I am learning. Watched some YouTube videos and decided to just have a go at it. This was my first time doing anything this big. Just using the materials that I have on hand. I made a roller out of delrin and seemed to work good. Will demold on Monday.
I really just want to make a couple of these fairings.
« Reply #21 on: April 09, 2023, 04:22:31 AM »
You can build a decent vacuum pump using a metal coffee can , some brass tubing, soldered into the can with an inexpensive fish tank air pump, and a board the can and pump are glued to the upsidedown can. Then poly sheet and caulk to make the bagging materials from..
You can actually get good results with what sounds like a Jerry rigged setup.
Epoxy resin needs thinned to work well and produces stronger layups than poly resin. Can be more brittle also. But it is best done with laminating resin, not epoxy glued as they don't have the working time needed and penetration of the cloth is harder if the resin isn't made for lamination work.
RC airplanes fuselages and wings are often built with the inexpensive air pump coffee can vacuum pumps.
« Reply #22 on: April 09, 2023, 04:26:51 AM »
Funny you mention that….I have this one for sale on FB marketplace.
Offline WideAWAKE
« Reply #23 on: April 09, 2023, 07:33:46 AM »
There are many ways to build a vac pump.
Fish tank pumps work, hospital pumps work…
For small parts I’ve even used a food sealer and large storage bags with a home vacuume
Nonetheless you can get a perfectly good hand layup with your molds. Just use the proper material and take your time.
If you don’t have a lot of skill AND your trying to skimp/use what you go/push things past their optimal than your really on a road to leas than stellar results.
« Reply #24 on: April 09, 2023, 07:59:00 AM »
Got it. Pics tomorrow.
