Author Topic: CB550K1 Cluch basket axial free play  (Read 337 times)
Offline Erny
« on: March 26, 2023, 01:45:39 PM »
When inspecting clutch of my CB550K1 I found that basket has axial plau about 0.7mm. There is nothing obviously worn, can somebody confirm is is normal? It looks to me quite a lot..
see video of my basket - I'm pushing collar while moving basket axially. Play is determined by length diff between collar and basket. Fische does not show any washer
https://youtube.com/shorts/kOtujX2WB-I
Honda service manual describe ho to adjust play of clutch center (washer under snap ring) but says nothing about basket axial play, nor any service limit...
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Kenzo1979
Re: CB550K1 Cluch basket axial free play
« Reply #1 on: March 26, 2023, 05:38:21 PM »
I can’t remember exactly how much play should or should not be there, but is your shim washer in there?
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
« Reply #2 on: March 26, 2023, 07:38:24 PM »
All the 550s I have recently done were like that.
It bugs me when the other SOHC4 bikes aren't that way, but considering that the 550 clutch is pressed toward the engine by the lifter all the time (and harder when the clutch lever is pulled), it won't go anywhere.
« Reply #3 on: March 26, 2023, 10:44:06 PM »
there should be a shim or two behind the circlip,might be hard to spot and stuck in the hub,# 15 in the picture.
 .1mm  90458-323-010
 .3mm  90459-323-010
 .5mm  90460-323-010
« Last Edit: March 26, 2023, 11:04:03 PM by dave500 »
Offline Erny
« Reply #4 on: March 27, 2023, 03:05:49 AM »
This is what I explained, shims you mention are intended to tune free play of inner basket, but I mentioned free play between collar 2 and outer basket 1. Only way to reduce that play would be to put washer under collar shoulder and this does not exist on fiche
Offline Deltarider
« Reply #5 on: March 27, 2023, 03:37:18 AM »
 .1mm  90458-323-010
 .3mm  90459-323-010
 .5mm  90460-323-010
IIRC 0,1mm, 0,3mm, 0,5mm or none at all. Anyway that was as far as the CB500. The CB500 I own has none.
I remember some 35 years ago, when I had planned to replace clutch diskes and springs, I've ordered the shims. I just had a look in my parts box and found the 0,1 and 0,5 one. I can't remember if back then I have also ordered the 0,3 mm one. Why the 0.1mm's outside is wider, I have no idea. Maybe the shop gave me the wrong one.
Than this. I've never known if these shims are meant to address wear or if one of them was selected at the assembly line, to address a then manifest play for each individual bike, if needed.
« Last Edit: March 27, 2023, 05:06:57 AM by Deltarider »
CB500K2-ED Excel black
Offline Erny
« Reply #6 on: March 27, 2023, 05:13:34 AM »
Thanks Delta, but still, these shims are to fix play of inner basket (and I'm well aware about it), not as in my case, outer one.
That's why I asked others, if such play of outer basket is normal on CB550 engines. I have no other to compare nor experience with from the past
« Reply #7 on: March 27, 2023, 06:19:23 AM »
Delta, those shims were selectively fitted on assembly to account for machining tolerances.
Offline Deltarider
« Reply #8 on: March 27, 2023, 06:54:15 AM »
@ Erny: Ooops! Sorry, I misread.
Thanks, Bryanj. I thought so too. At around 75.000 km on the odometer, I've replaced springs and disks. BTW, both disks and springs were exactly at the minimum as described in the Shop Manual CB500-550. I had bought the shims at forehand, but was surprised I didn't need either one of them after all.
« Last Edit: March 27, 2023, 07:31:56 AM by Deltarider »
« Reply #9 on: March 27, 2023, 11:39:34 PM »
once assembled those shims will tighten up the whole affair.
« Reply #10 on: March 28, 2023, 01:06:47 AM »
you have washer #14 in place? 90455-374-000
Offline Erny
« Reply #11 on: March 28, 2023, 01:24:18 AM »
Yes I do
I concluded this play as normal and will let it be as is
« Last Edit: March 28, 2023, 01:28:36 AM by Erny »
