Author Topic: sticky floats 750  (Read 3910 times)
vince
sticky floats 750
« on: March 11, 2007, 06:46:01 PM »
what to do ?
Offline 736cc
Re: sticky floats 750
« Reply #1 on: March 15, 2007, 05:37:40 AM »
Sometimes you gotta "tweak" the floats a little because they hang-up on carb bowl. Sometimes carb bowl gasket fouls float. Sometimes the bowl is clipped-on slightly crooked. Sometimes the float is "sunk" (leaks and filled w/ gas). To test this, remove float, shake it and listen for gas sloshing around inside float. If so, replace it. All this can be done w/o removing carbs from bike in a couple minutes.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: March 15, 2007, 10:07:51 AM »
Maybe also check the float pivot pins to make sure they are clean, no burs, etc.
« Reply #3 on: March 15, 2007, 03:31:43 PM »
You may also want to check the needle valves, sometimes varnish can build up on them and they get sticky.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: March 16, 2007, 04:12:24 PM »
You MUST limit the drop on the float.
The contact point between the float and the needle valve is critical in most Carbs. As the float drops, the angle increases and the float pushes the needle off to the side as it tries to close the valve.
This causes the needle to bind in it's bore. It doesn't seat so it leaks/dumps fuel on the deck when you park it.
So You whack it with something and it quits leaking? For the moment.
It rattles around while you are driving but when you kill the motor........... you do the math :-*
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
