Author Topic: Advice adding LED turn signals. Which relays?  (Read 1274 times)
Offline preacher
« on: March 26, 2023, 09:51:27 PM »
Looking to replace oem signals with smaller LED's and can't seem to solidify which relays are needed in order to make them operate properly.
Bike is a 78 CB550.
Any insight is appreciated.
TY
« Last Edit: March 30, 2023, 12:25:33 PM by preacher »
1978 CB550 Four
Re: Advice adding LED turn signals. Which relays?
« Reply #1 on: March 27, 2023, 06:23:44 AM »
You need and electronic relay that states it is good for led and it will only work properly if you have a seperate idiot light for each side, which the 79 should have
Offline Erny
« Reply #2 on: March 27, 2023, 06:32:47 AM »
you can adopt also for 1 common idiot light, I have it like that.
I keep using normal bulbs, but with LED capable relay (electronic) - reason is that bulbs are on immidiately after I push blinker switch - much safer on the road. On legacy bimetal relay it takes time till bulbs are on after you touch switch.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
« Reply #3 on: March 27, 2023, 09:41:36 AM »
No, the bimetal comes on immediately and turns off with heat
Offline Erny
« Reply #4 on: March 27, 2023, 11:26:47 AM »
Ok then I'm wrong, you are right Just wanted to say that ones "standard" I had on my CB750 and 550 had the same behavior - they came on only after waiting period...
Offline preacher
« Reply #5 on: March 27, 2023, 10:12:45 PM »
Thanks for the feedback.
Any insight on which ones to get? PN?
1978 CB550 Four
Offline newday777
« Reply #6 on: March 28, 2023, 03:16:55 AM »
Bike is a 79 CB550.
TY
Welcome to the forum preacher
Please verify what bike you have as there was no 1979 CB550.
Is your flasher relay 2 prong or 3 prong?
« Last Edit: March 28, 2023, 03:19:34 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #7 on: March 28, 2023, 03:41:50 AM »
Bike is a 79 CB550.
TY
If you have a 2 prong relay, get this flasher with the ground lead and put the wired lug to a ground screw or cut off the lug and put on a barrel connector and plug it into the extra green wire in the harness(if you have a 1978 and earlier bike)
https://www.walmart.com/ip/CEC-Industries-EF32RL-Electronic-Turn-Signal-Flasher-Relay-LED-Compatible-2-Ground-Wire-Prongs-12-Volts/804573903
Stu
My current rides
Prior bikes....
Offline preacher
« Reply #8 on: March 28, 2023, 02:13:32 PM »
Bike is a 79 CB550.
TY
Thanks for catching that..yes it is a '78. Updated my profile.
I will have to look. Did the '78 come with both style/options?
1978 CB550 Four
Offline newday777
« Reply #9 on: March 28, 2023, 04:26:15 PM »
78 should have a 2 prong flasher.
When I asked, I wasn't sure what bike you had.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #10 on: March 28, 2023, 04:27:10 PM »
BTW
Go to the new members section and introduce yourself and your bike. Pictures are always welcome.
Stu
My current rides
Prior bikes....
Offline Bodi
« Reply #11 on: March 28, 2023, 05:59:13 PM »
If you like the instant on behaviour, an electronic 2 prong flasher is not for you. There are three prong electronic ones that work with LEDs and do it. There are, unfortunately, several types of 3 prong flashers and some will just pop your fuse the first time you test (they add a second output for trailer lights, idiot light, or something... so power is sent to what you think is the ground connection). The right kind for cars/trucks will flash fast with LEDs... they have a current sensing function that does the fast flash to flag a burnt out "normal" bulb. I like the fast flash though.
Offline newday777
« Reply #12 on: March 28, 2023, 06:07:49 PM »
Never heard of that.
Post a link where to get it and examples of that happening.
Stu
My current rides
Prior bikes....
