Author Topic: Seat covers  (Read 438 times)
Offline TimmyC
Seat covers
« on: March 31, 2023, 07:37:18 AM »
Hello,
I am new to the forum and just bought a 77 CB750K. I would like to replace the seat cover with an earlier model year, 1971 or 1972. Does anyone know if it will fit? I understand the the foam and upper shapes are different but is the seat pan the same basic shape, ie length and width?
Thanks for the help!
Tim
Offline Lucien Harpress
Re: Seat covers
« Reply #1 on: March 31, 2023, 09:43:07 AM »
There's a couple differences between the 71 and 72-on at least.  Foam shape is pretty identical between 71 and 72, but I can't speak for what they look like compared to the year you have.  The overall shape of the pan is the same.  The difference is how the cover attaches.  71 and earlier have metal "teeth" that grip the cover, and the chrome trim is a separate piece.  72 and later, the factory cover had chrome trim attached to the vinyl, and this was held on place by larger blunt tabs.
The issue arises because this is really hard to replicate on new covers, so most reproductions call for you to somehow attach the cover to the pan in another way (glue, etc.), then cover the edge with decorative chrome edge trim.  It looks okay, but is a bit of a pain compared to pans with the teeth.
Another option is to use an early pan, but the seat latch hardware is different (and not easily swapped over to the later catches), and all early components are quite a bit more expensive than the post-1972 stuff.
« Last Edit: March 31, 2023, 09:44:49 AM by Lucien Harpress »
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Re: Seat covers
« Reply #2 on: March 31, 2023, 10:01:08 AM »
If not mistaken, the '77-78 seats are a bit longer [it's been a couple years since I sold my '78]
Can we ask why you want to do it?  BTW - the '77 and the '78 are just a bit different but use the same pan.
Offline TimmyC
Re: Seat covers
« Reply #3 on: March 31, 2023, 12:25:49 PM »
Thanks for the info. I really like the lower profile of the older seats. The 77 & 78 have the hump in the center. As a side note I believe that my bike has a 78 seat on it based on the info from Honda 750 Expert website.
